ROMA Snap
ROMA Snap captures the requirements for service integration based on user inputs by way of Natural Language Processing (NLP) machine learning, matching triggers, connectors, and data processors supported by the system to generate a composite application. You can further configure and orchestrate the generated composite application for building and deployment.
- Log in to the new ROMA Connect console.
- On the Workbench page, click ROMA Snap.
- In the pop-up box, enter the description of the composite application to be created, or click the action templates under the text box.
- Click the underlined connector or processor to replace it with a desired one in the drop-down list.
- Press Enter, and then click Apply to generate a composite application.
- On the canvas for editing the composite application, configure and orchestrate the flow task.
You can also configure components with interactive inputs.
- Click Save in the upper right corner.
- In the upper left corner, click the edit button next to the composite application name. In the dialog box displayed, modify the name and enter a description, and click Yes.
