FTP
The FTP connector is a channel for file transfer based on the FTP/SFTP protocol. Through the FTP connector, files can be exchanged with an external FTP server.
- The File Transfer Protocol (FTP) is in the TCP/IP protocol group. It consists of two parts: FTP server and FTP client. The FTP server is used to store files. Users can use the FTP client to access resources on the FTP server.
- The SSH File Transfer Protocol (SFTP) is a secure version of FTP and a part of the SSH protocol. SFTP enables easy data transmission and data access through the data flow shell. SFTP, also known as the SSH file transfer protocol, provides a secure connection to transfer files and traverses file systems on local and remote systems.
By default, FTP uses TCP ports 20 and 21. Port 20 is used to transmit data, and port 21 is used to transmit control information (commands). Whether to use port 20 as the port for data transmission depends on the FTP transmission mode. In the active mode, the data transmission port number is 20. In the passive mode, the port is determined after the negotiation between the server and the client.
Creating an FTP Connection
- Log in to the new ROMA Connect console.
- In the navigation pane on the left, choose Connector. On the page displayed, click New Connection.
- Select the FTP connector.
- In the dialog box displayed, configure the connector and click OK.
Name
Enter the connector instance name.
Protocol
Protocol used by the FTP connector. Options are FTP and SFTP.
Host IP
IP address of the FTP server.
Port
Username
FTP username.
Authority Type
This parameter is required when Protocol is set to SFTP.
Select the authentication mode of SFTP.
- Password
- Public Key
Private Key
This parameter is required when Protocol is set to SFTP and Authority Type is set to Public Key.
Enter the complete private key content, starting with -----BEGIN.
Private Key Passphrase
Enter the private key password.
Password
FTP user password.
Enable Passive Mode
This parameter is required when Protocol is set to FTP.
Whether to enable the passive mode.
Passive mode resolves FTP connection failures caused by firewalls or routers (server must support passive mode).
Enter the description of the connector to identify it.
Action
- Writing data to a file
- Listing directory contents
- Obtaining file content
- Copying a file
- Moving a file
- Deleting a file
- Obtaining file metadata
- Extracting a file
Configuration Parameters
Parameter |
Description |
Path |
Enter the relative path of the directory. If the home directory of the current FTP connection is /home/ftpuser and the directory path is /home/ftpuser/data, set this parameter to /data. |
File Name |
Enter the name of the target file. |
Content |
Enter the content to be written. |
Write Policy |
Select a policy.
Parameter |
Description |
Path |
Marker |
Return the result list from the file specified by the marker path. If this parameter is empty, results from all files are returned. If the home directory of the current FTP connection is /home/ftpuser and the marker path is /home/ftpuser/data/file.txt, set this parameter to /data/file.txt. |
Return Limit |
Maximum number of files that can be returned. The maximum value is 50. |
Is Recursive |
Whether to search for files in subdirectories recursively.
Parameter |
Description |
Path |
File Name |
Name of the file to be obtained. |
Parameter |
Description |
Path |
File Name |
Name of the file to be copied. |
New Path |
New File Name |
New name of the file after the copy. |
Override Policy |
Whether to overwrite the file with the same name.
Parameter |
Description |
Original Path |
New Path |
File Name |
New name of the file after the move. |
Override Policy |
Parameter |
Description |
Path |
File Name |
Name of the file to be deleted. |
Parameter |
Description |
Path |
File Name |
Name of the file from which metadata is to be extracted. |
Parameter |
Description |
Compressed Package Path |
Decompression Path |
File Name |
Name of the file to be extracted. |
Override Policy |
