Asymmetric Encrypt/Decrypt
The asymmetric encrypt/decrypt processor is used to encrypt plaintext and decrypt ciphertext by using the specified asymmetric encryption algorithm.
Configuration Parameters
Parameter |
Description |
Private Key |
Base64-encoded, mandatory for decryption. |
Public Key |
Base64-encoded, mandatory for encryption. |
Operation |
Asymmetric encryption or decryption. |
Encryption Algorithm |
Currently, only RSA is supported. |
Plaintext |
Mandatory when Operation is set to Asymmetric Encrypt. Plaintext to be encrypted. |
Ciphertext |
Mandatory when Operation is set to Asymmetric Decrypt. Base64-encoded ciphertext to be decrypted. |
Padding Mode |
Plaintext padding mode. Currently, only RSA_PKCS1_OAEP_PADDING is supported. |
OAEP Hash Algorithm |
Mandatory when Padding Mode is set to RSA_PKCS1_OAEP_PADDING. Options are SHA256 and SHA384. |
