PostgreSQL
Updated on 2024-11-25 GMT+08:00
The PostgreSQL connector allows you to connect applications with the PostgreSQL database, and manage data transmission.
  • PostgreSQL is a full-featured, open-source object-relational database.
  • The default PostgreSQL port number is 5432. The administrator can change the port number as required.
Creating a PostgreSQL Connection
  1. Log in to the new ROMA Connect console.
  2. In the navigation pane on the left, choose Connector. On the page displayed, click New Connection.
  3. Select the PostgreSQL connector.
  4. In the dialog box displayed, configure the connector and click OK.
    Name
    Enter the connector instance name.
    Region
    Select a region.
    Project
    Select a project.
    Instance
    Select an instance for subsequent connectivity verification.
    Connection and Security
    Select the connection mode for the database.
    • Default: The system automatically concatenates data source connection character strings based on configured data.
    • Professional: You need to specify the data source connection string manually.
    IP Address
    Required when Connection and Security is set to Default.
    Enter the IP address of the database.
    Port
    Enter the port number to which the database is connected.
    Database Name
    Enter the name of the database to be connected.
    Connection String
    Required when Connection and Security is set to Professional.
    Enter the JDBC connection string of the PostgreSQL database, for example, jdbc:postgresql://{hostname}:{port}/{dbname}.
    Username
    Enter the username used to connect to the database.
    Password
    Enter the password used to connect to the database.
    Enter the description of the connector to identify it.
Action
  • Obtaining records
  • Adding records
  • Updating records
  • Replicating records
  • Obtaining incremental records
  • Deleting records
  • Custom SQL
Configuring Parameters
NOTICE:
The PostgreSQL connector supports English table names only.
Table 1 Obtaining records
Table Name
Select or enter the table name in the database to be queried.
Field Name
Select the field name of the data table to be queried.
WHERE Condition
Set the condition value in single quotation marks.
Order By Field
Enter the sorting field of the returned result.
Limits
Enter the number of records on each page in the returned result.
Offset
Enter the offset of the pagination query.
Table 2 Adding records
Table Name
Select or enter the name of the table to which data is to be inserted.
Data to Insert
Enter the target field value in single quotation marks.
Table 3 Updating records
Table Name
Select or enter the name of the table where data is to be updated.
Update Data
WHERE Condition
Table 4 Replicating records
Table Name
Select or enter the name of the table where data is to be replicated.
Clear Table
Whether to clear the table each time data is replicated.
Table 5 Obtaining incremental records
Table Name
Select or enter the name of the table to obtain incremental records.
Field Name
WHERE Condition
Order By Field
Start Timezone for incremental database selection
Start time zone for obtaining incremental data.
Incremental Selection Timestamp Field Name
Timestamp field for obtaining incremental data.
Incremental Selection Timestamp Initial Value
Initial timestamp for obtaining incremental data.
Reset Initial Incremental Selection Time
Whether to enable the reset of the initial time for obtaining incremental data.
Incremental Selection Compensation Period (ms)
Time compensation for obtaining incremental data.
Table 6 Deleting records
Table Name
Select or enter the name of the table where data is to be deleted.
WHERE Condition
Table 7 Custom SQL
Statement
Enter the native SQL statement for operating the database.
  • Statements display all your inputs as plain text. Do not include sensitive information.
  • Be careful when using non-query statements such as drop and truncate.
