Db2
Updated on 2024-04-23 GMT+08:00
The Db2 connector is used to connect to a Db2 database by establishing and maintaining the connection between applications and the database, and managing data transmission.
  • Db2 is a relational database management system.
  • The default Db2 port number is 5000. The administrator can change the port number as required.
Creating a Db2 Connection
  1. Log in to the new ROMA Connect console.
  2. In the navigation pane on the left, choose Connector. On the page displayed, click New Connection.
  3. Select the Db2 connector.
  4. In the dialog box displayed, configure the connector and click OK.
    Name
    Enter the connector instance name.
    Region
    Select a region.
    Project
    Select a project.
    Instance
    Select an instance for subsequent connectivity verification.
    Connection and Security
    Select the connection mode for the database.
    • Default: The system automatically concatenates data source connection character strings based on configured data.
    • Professional: You need to specify the data source connection string manually.
    IP Address
    Required when Connection and Security is set to Default.
    Enter the IP address of the database.
    Port
    Enter the port number to which the database is connected.
    Database Name
    Enter the name of the database to be connected.
    Connection String
    Required when Connection and Security is set to Professional.
    Enter the JDBC connection string of the Db2 database, for example, jdbc:db2://hostname:port/dbname.
    Username
    Enter the username used to connect to the database.
    Password
    Enter the password used to connect to the database.
    Enter the description of the connector to identify it.
Action
  • Obtaining records
  • Adding records
  • Updating records
  • Deleting records
Configuration Parameters
Table 1 Obtaining records
Table Name
Name of the table where data will be queried.
Column Name
Column name of the data table.
WHERE Condition
Enter the condition value (enclose it in single quotation marks) of the data to be queried.
Order By Field
Enter the sorting fields of the returned result.
Limits
Enter the number of records on each page in the returned result.
Offset
Enter the offset of the pagination query.
Table 2 Adding records
Table Name
Name of the table where data will be inserted.
Data to Insert
Enter the value (enclose it in single quotation marks) to be inserted.
Table 3 Updating records
Table Name
Name of the table where data will be updated.
Data to Update
Enter the updated value (enclose it in single quotation marks).
WHERE Condition
Enter the condition value (enclose it in single quotation marks) of the data to be updated.
Table 4 Deleting records
Table Name
Name of the table where data will be deleted.
WHERE Condition
Enter the condition value (enclose it in single quotation marks) of the data to be deleted.
