Timer
A timer is a trigger that can trigger a specific operation at a preset interval. It can trigger an operation periodically within a specified period or at a specified time point. A timer is used to implement scheduled tasks and scheduling.
Action
- Every Minute
- Hourly
- Daily
- Weekly
- Monthly
- Fixed Interval
- Fixed Interval (Specified Time)
Configuration Parameters
Parameter |
Description |
Trigger Interval |
Every hour, the task is executed at a fixed interval from the start of the hour. Range: 1 to 60 |
Triggering Rule |
Custom Trigger Rule |
This parameter is displayed when Trigger Rule is set to Custom.
Time Zone |
Task Mode |
Execute Once at Once |
Whether to execute the task immediately after startup. |
Parameter |
Description |
Start |
Time from 00:00 (the task is also executed within the hour). Range: 0 to 23 |
End |
Time from 00:00 (the task is also executed within the hour). Range: 0 to 23. The value must be greater than the start time. |
Trigger Minute |
The minute the task is triggered. Range: 0 to 59 |
Rule |
Time Zone |
Task Mode |
Parameter |
Description |
Rule |
Time |
Example: 00:59 |
Time Zone |
Task Mode |
Parameter |
Description |
Weekly Trigger Day |
Select the day of the week when the flow is triggered.
Time |
Example: 00:59 |
Time Zone |
Task Mode |
Parameter |
Description |
Trigger Rule |
Select a trigger rule.
Specified Date |
This parameter is displayed when Trigger Rule is set to Specified Date. Options: 1st to 31st of each month. |
Trigger Time |
Example: 00:59 |
Time Zone |
Task Mode |
Parameter |
Description |
Interval |
Value of the interval |
Execution Interval Unit |
Task Mode |
Parameter |
Description |
Unit |
Interval |
Executed On (Day) |
This parameter is displayed when Unit is set to Month. The value ranges from 1 to 31. For example, 1: The task is executed on the first day of each month. 1,15: The task is executed on the first and fifteenth days of each month. |
Executed At (Hour) |
This parameter is displayed when Unit is set to Day or Month. The value ranges from 0 to 23. For example, 0: The task is executed at 00:00 every day. 0,12: The task is executed at 00:00 and 12:00 every day. |
Executed At (Minute) |
This parameter is displayed when Unit is set to Hour, Day, or Month. The value ranges from 0 to 59. For example, 0: The task is executed at the 0th minute of every hour. 0,30: The task is executed at the 0th and 30th minutes of every hour. |
Executed At (Second) |
This parameter is displayed when Unit is set to Minute, Hour, Day, or Month. The value ranges from 0 to 59. For example, 0: The task is executed at the 0th second of every minute. 0,30: The task is executed at the 0th and 30th seconds of every minute. |
Task Mode |
Parameter |
Description |
Next scheduled time |
Start time of the next execution. |
Previous scheduled time |
Start time of the last execution. |
Start time |
Start time of node execution. |
End time |
End time of node execution. |
Execution time |
Node execution duration, in milliseconds. |
