Splitter
The splitter processor splits the data transferred to this node based on the specified expression and transfers the split data to subsequent nodes through Node Variables.
Generally, a splitter processor is followed by a filter processor.
Splitter is an asynchronous processing component. When a task contains a Splitter node, each split data segment is processed separately.
Configuration Parameters
Parameter |
Description |
Expression |
Data to be split. Example: Reference ${payload.data} from a node or enter data directly: {"data":[{"id":1},{"id":2}]}. |
Delimiter |
Delimiter used to split data. For example, if the payload data is {"data":[{"id":1},{"id":2}]}, you can use ${payload.data} and the delimiter (,) to split the data into {"id":1} and {"id":2}. |
Output variables
Parameter |
Description |
payload |
Data splitting result. |
Start time |
Start time of node execution. |
End time |
End time of node execution. |
Execution time |
Node execution duration, in milliseconds. |
Example
Example 1
Input:
- Data: {"data":[{"id":1},{"id":2}]}
- Delimiter: ,
Output:
- {"id":1}
- {"id":2}
