Updated on 2025-05-08 GMT+08:00
MySQL
The MySQL connector allows you to connect applications with the MySQL database, and manage data transmission.
  • MySQL is a popular, open-source relational database widely used as the backend of web applications. It supports multiple operating systems, such as Windows, Linux, Unix, and macOS X. MySQL features high performance, reliability, and flexibility, and is popular among enterprises and developers.
  • The default MySQL port number is 3306. The administrator can change the port number as required. MySQL supports multiple storage engines, including InnoDB, MyISAM, and MEMORY. Each storage engine has its own pros and cons and can be configured flexibly.
Creating a MySQL Connection
  1. Log in to the new ROMA Connect console.
  2. In the navigation pane on the left, choose Connector. On the page displayed, click New Connection.
  3. Select the MySQL connector.
  4. In the dialog box displayed, configure the connector and click Test connection. After the connection is successful, click OK.
    Name
    Enter the connector instance name.
    Region
    Select a region.
    Project
    Select a project.
    Instance
    Select an instance for subsequent connectivity verification.
    Connection and Security
    Select the connection mode for the database. Currently, the Default mode is supported.
    IP Address
    Enter the IP address of the database.
    Port
    Enter the port number to which the database is connected.
    Database Name
    Enter the name of the database to be connected.
    Username
    Enter the username used to connect to the database.
    Password
    Enter the password used to connect to the database.
    Enter the description of the connector to identify it.
Action
  • Obtain Record: Retrieve data from a MySQL table by specifying the table name, WHERE condition, Order By field, Limit, and Offset.
  • Incrementally Obtain Record: Periodically fetch new or updated records from a MySQL table since a specified start time. This action must be used together with a timer.
  • Add Record: Insert a new row into a specified MySQL table.
  • Update Record: Update one or more rows in a specified MySQL table by applying filter criteria and providing new values.
  • Replicate Record: Replicate data to a specified MySQL data table. This action must be used together with a timer and CDC must be enabled
  • Delete Record: Delete one or more rows from a specified MySQL table based on filter criteria.
  • Custom SQL: Execute native SQL statements for operations on the MySQL database.
Configuring Parameters
  • Obtaining records
    Table 1 Configuration parameters
    Table Name
    Select or enter the table name in the database to be queried.
    Field Name
    Select the field name of the data table to be queried. If this parameter is not specified, all fields will be returned.
    WHERE Condition
    Filter query results using conditions like column_name='value'. Supported operators: =, !=, >, <, >=, <=, like, in, not in, is null, and is not null.
    Order By Field
    Specify one or more columns to sort results, for example, id DESC.
    Limits
    Limit the number of returned rows, for example, 100.
    Offset
    Specify the starting row number for returned data, for example, 15.
    Data Schema
    Configure output fields. Fields are auto-generated when a table is selected but can be edited manually.
    Table 2 Output parameters
    Payload
    Response in JSON format, with keys as the database field names and values as their corresponding data. Entries on each line are comma-separated. For payload details, see Referencing Variables.
    Selected Count
    Number of rows in the query result. For details about the property, see Referencing Variables.
    After the execution is successful, the payload value is as follows:
            "Product_Id": "f47ac10b-58cc-4372-a567-0e02b2c3d479",
            "Created_Time": "2024-11-29T15:06:09Z",
            "Product_Price": 1299,
            "Product_Name": "Product A",
            "Product_Desc": "Product A"
            "Product_Id": "c3d7b1b7-4cd1-4d72-b1b8-7d38e1a1fe5a",
            "Created_Time": "2024-11-29T15:06:38Z",
            "Product_Price": 1099,
            "Product_Name": "Product C",
            "Product_Desc": "Product C"
  • Obtaining incremental records
    Table 3 Configuration parameters
    Table Name
    Select or enter the name of the table to obtain incremental records.
    Field Name
    WHERE Condition
    Order By Field
    Start Timezone for incremental database selection
    Start time zone for obtaining incremental data.
    Incremental Selection Timestamp Field Name
    Timestamp field for obtaining incremental data. The selected field must be of the time or timestamp type.
    Incremental Selection Timestamp Initial Value
    Initial timestamp for obtaining incremental data.
    Reset Initial Incremental Selection Time
    Whether to enable the reset of the initial time for obtaining incremental data. If this function is disabled, the system obtains incremental data from the current time.
    Incremental Selection Compensation Period (ms)
    Specify the extended time range (ms) to avoid missing records that may arrive late.
    Data Schema
    Table 4 Output parameters
    Payload
    Example of obtaining incremental records:
    Timer (triggered every day) → MySQL (obtaining incremental records) → Log collection
  • Adding records
    Table 5 Configuration parameters
    Table Name
    Enter the name of the table where data will be inserted.
    Data to Insert
    Enter the value of the target field.
    Data Schema
    Configure output fields. Fields are auto-generated when a table is selected. This setting is not applicable for this action.
    Table 6 Output parameters
    Updated Count
    Row number of the inserted data. For details about the property, see Referencing Variables.
  • Updating records
    Table 7 Configuration parameters
    Table Name
    Select or enter the name of the table where data is to be updated.
    Data to Update
    WHERE Condition
    Select the target row using conditions like column_name='value'. Supported operators: =, !=, >, <, >=, <=, like, in, not in, is null, and is not null.
    Data Schema
    Table 8 Output parameters
    Updated Count
    Row number of the updated data. For details about the property, see Referencing Variables.
  • Replicating records
    Table 9 Configuration parameters
    Table Name
    Select or enter the name of the table where data is to be synchronized.
    Clear Table
    Whether to clear the table each time data is replicated.
    Table 10 Output parameters
    Payload
    This action supports the following scenarios:
    1. Stream data from one database to another with identical table names
      MySQL: Capture Database Changes → Replicate Record
      Timer (any action) → MySQL (Incrementally Obtain Record) → MySQL (Replicate Record)
    2. Stream data between databases with different table names (data mapping processor for table name mapping)
      MySQL (Capture Database Changes) → Data Mapper → MySQL (Replicate Record)
      Timer (any action) → MySQL (Incrementally Obtain Record) → Data Mapper → MySQL (Replicate Record)
  • Deleting records
    Table 11 Configuration parameters
    Table Name
    Select or enter the name of the table where data is to be deleted.
    WHERE Condition
    Data Schema
    Table 12 Output parameters
    Updated Count
    Row number of the deleted data. For details about the property, see Referencing Variables.
  • Custom SQL
    Table 13 Custom SQL
    Statement
    Statements display all your inputs as plain text. Do not include sensitive information. Only one select, update, insert, or delete statement can be executed. The select statement can return up to 500 records.
    If the table name contains a hyphen (-), use backquotes (`) to enclose the table name. For example, insert into `bfs-test`.source_01(id, name) values (01, 'testname01');. Otherwise, a syntax error is reported.
    Table 14 Output parameters
    Payload
    Updated count
    Number of updated rows.
    Selected count
    Number of rows of data queried.
    Start time
    Start time of node execution.
    End time
    End time of node execution.
    Execution time
    Node execution duration, in milliseconds.
