HTTP Response
The HTTP response connector is used to customize the information returned by an API. This way, an OpenAPI will return the specified response code and response body after it is called.
Action
Custom HTTP response
Configuration Parameters
Parameter |
Description |
Header |
Configure the response header parameter of the API response. Use constants, or data from previous nodes by referencing variables. |
Body |
Configure the API response body. Use constants, or data from previous nodes by referencing variables. Predefined response codes: 1. 200-OK 2. 201-CREATED 3. 400-BAD REQUEST 4. 500-INTERNAL SERVER ERROR. |
Response Code |
Configure the response code of the API response. Select an existing response code or customize one. |
Custom Status Code |
Required only when Response Code is set to Custom. Enter a custom status code. |
