Importing and Exporting a Composite Application
ROMA Connect allows you to import and export composite applications using files.
- Importing composite applications in JSON format
- Exporting composite applications in JSON format
- After a composite application with custom connectors is exported, it cannot be imported to other environments.
- The connection instance information of a connector cannot be exported.
- Log in to the new ROMA Connect console.
- In the navigation pane on the left, choose Application. On the page displayed, click the target composite application.
- Click
on the composite application and choose Export to export the composite application file in JSON format to the local host.
Importing a Composite Application
- In the navigation pane on the left, choose Application. On the page displayed, click Create.
- In the Select Template box, choose Import under Import from Files.
- On the page displayed, click
to select a composite application file in JSON format. - Click Upload to import the composite application.
If a message says the composite application name already exists during import, either create a new version on the file selection page or rename the name field in the composed_apps section of the imported JSON file, then try importing again.
