Help Center/ Config/ User Guide/ Conformance Packages/ Organization Conformance Packages/ Viewing an Organization Conformance Package
Updated on 2025-08-25 GMT+08:00
An organization administrator or a delegated administrator of Config can only view organization conformance packages created by themselves.
Each member can view organization packages that are deployed to their accounts in the conformance package list. If you create an organization conformance package using an account, you can only use the same account to delete the package. Members can only initiate resource evaluation and view evaluation results.
This section consists of Viewing an Organization Conformance Package (for Administrators), Viewing an Organization Conformance Package (for Organization Members), and Deployment Statuses of Organization Rules.
  1. Log in to the management console as an organization administrator or a delegated administrator of Config.
  2. Click in the upper left corner of the page. Under Management & Governance, select Config.
  3. On the left navigation pane, choose Conformance Package.
  4. Select the Organization Conformance Package tab to view all created organization conformance packages and their deployment statuses.
  5. Click the name of a target organization conformance package to view details.
    On the left, view deployed and excluded member accounts. On the right, view package details.
    Figure 1 Organization details of an organization conformance package
  1. Log in to the management console as an organization member.
  4. On the Conformance Packages tab, click the name of a target organization conformance package in the list to view details.
    On the details page, view package basic information, configurations, rules included, and the evaluation result of each rule.
    Locate a target rule and click the rule name to go to the details page. Non-compliant resources evaluated using the rule are displayed by default.
    Figure 2 Viewing an organization conformance package (for organization members)
    A deployed organization conformance package will be displayed in the rule list of every member in the organization. The system automatically adds the Org field before the name of an organization conformance package.
    Members can only trigger rules in an organization conformance package and view the evaluation results. They cannot delete an organization conformance package.
Table 1 Deployment statuses of organization rules
Value
Status
CREATE_IN_PROGRESS
Deploying
An organization conformance package is being created.
UPDATE_IN_PROGRESS
Updating
An organization conformance package is being updated.
DELETE_IN_PROGRESS
Deleting
An organization conformance package is being deleted.
CREATE_FAILED
Abnormal
An organization conformance package fails to be deployed to one or more member accounts.
UPDATE_FAILED
Update failed
An organization conformance package fails to be updated in one or more member accounts.
DELETE_FAILED
Deletion failed
An organization conformance package fails to be deleted in one or more member accounts.
CREATE_SUCCESSFUL
Deployed
An organization conformance package has been deployed to all member accounts.
UPDATE_SUCCESSFUL
Updated
An organization conformance package has been updated in all member accounts.
