Updated on 2025-08-25 GMT+08:00
Compliance Package for GDPR Standards
Exemption Clauses
This package provides you with general guide to help you quickly create scenario-based conformance packages. The conformance package and rules included only apply to cloud service and do not represent any legal advice. This conformance package does not ensure compliance with specific laws, regulations, or industry standards. You are responsible for the compliance and legality of your business and technical operations and assume all related responsibilities.
Rules
Table 1 Default rules of the GDPR standard check
Guideline No.
Rule
Rule Name
C.CS.FOUNDATION.G_5_1.R_5
obs-bucket-ssl-requests-only
OBS Buckets Should Deny Requests Not Encrypted with SSL
C.CS.FOUNDATION.G_5_2.R_1
volumes-encrypted-check-by-default
Disk Encryption Are Enabled
C.CS.FOUNDATION.G_5_3.R_1
sfsturbo-encrypted-check
KMS Encryption Is Enabled for SFS
C.CS.FOUNDATION.G_5_4.R_1
cbr-backup-encrypted-check
CBR Backup Encryption Check
C.CS.FOUNDATION.G_5_4.R_4
sfsturbo-last-backup-created
SFSturbo Backup Time Window Check
evs-last-backup-created
EVS Backup Time Check
ecs-last-backup-created
ECS Backup Time Window Check
C.CS.FOUNDATION.G_6_1.R_1
rds-instance-ssl-enable
SSL Is Enabled for RDS DB Instances
C.CS.FOUNDATION.G_6_1.R_7
rds-instance-enable-auditLog
Audit Logging Is Enabled for RDS DB Instances
C.CS.FOUNDATION.G_6_2.R_1
dds-instance-enable-ssl
SSL Has Been Enabled for DDS DB Instances
C.CS.FOUNDATION.G_6_4.R_5
gaussdb-instance-enable-auditLog
Audit Logging Is Enabled for GaussDB Instances
C.CS.FOUNDATION.G_7_3.R_1
dws-enable-kms
KMS Encryption Check
C.CS.FOUNDATION.G_7_3.R_4
dws-enable-log-dump
Audit Log Dump Is Enabled for DWS Clusters
C.CS.FOUNDATION.G_7_3.R_6
dws-enable-ssl
SSL Encryption Is Enabled for DWS Clusters
C.CS.FOUNDATION.G_2.R_1
multi-region-cts-tracker-exists
There Are CTS Trackers In the Specified Regions
