Help Center/ Config/ User Guide/ Conformance Packages/ Conformance Package Templates/ Best Practices for Virtual Private Cloud
Updated on 2025-01-20 GMT+08:00
The following table lists the rules and solutions included in this conformance package template.
Table 1 Conformance package description
Rule
Cloud Service
vpc-default-sg-closed
vpc
If a default security group allows all inbound or outbound traffic, this security group is noncompliant.
vpc-sg-attached-ports
vpc
This rule checks if a security group is associated with any elastic network interface. If a security group is not attached to any elastic network interface, this security group is noncompliant.
vpc-sg-ports-check
vpc
If a security group has the source address set to 0.0.0.0/0 or ::/0 and opens all TCP/UDP ports, this security group is noncompliant.
vpc-sg-restricted-ssh
vpc
If a security group allows all inbound traffic (with the source address set to 0.0.0.0/0 or ::/0) and opens the TCP 22 port, this security group is noncompliant.
vpc-sg-by-white-list-ports-check
vpc
If a security group allows traffic to a non-whitelisted port, this security group is noncompliant.
