Best Practices for Data Transmission Encryption
The following table lists the rules and solutions included in this conformance package template.
Rule |
Cloud Service |
Description |
apig-instances-ssl-enabled |
apig |
If no SSL certificates are attached to a dedicated APIG gateway, this gateway is considered noncompliant. |
cdn-enable-https-certificate |
cdn |
If a domain does not have an HTTPS certificate configured, this domain is noncompliant. |
cdn-origin-protocol-no-http |
cdn |
If a domain does not have HTTPS configured for communication between CDN and origins, this domain is noncompliant. |
css-cluster-https-required |
css |
If a CSS cluster does not have HTTPS enabled, this cluster is noncompliant. |
css-cluster-security-mode-enable |
css |
If a CSS cluster does not support the security mode, this cluster is noncompliant. |
dcs-memcached-enable-ssl |
dcs |
If a DCS Memcached instance can be accessed through public networks but does not support SSL, this instance is noncompliant. |
dcs-redis-enable-ssl |
dcs |
If a DCS Redis instance can be accessed over public networks but does not support SSL, this instance is noncompliant. |
dds-instance-enable-ssl |
dds |
If SSL is not enabled for a DDS instance, this instance is noncompliant. |
dms-kafka-not-enable-private-ssl |
dms |
If a DMS Kafka instance does not enable SSL for private access, this instance is noncompliant. |
dms-kafka-not-enable-public-ssl |
dms |
If a DMS Kafka instance does not enable SSL for public access, this instance is noncompliant. |
dms-rabbitmq-not-enable-ssl |
dms |
If a DMS RabbitMQ instance does not have SSL enabled, this instance is noncompliant. |
dms-rocketmq-not-enable-ssl |
dms |
If a DMS RocketMQ instance does not have SSL enabled, this instance is noncompliant. |
dws-enable-ssl |
dws |
If SSL is not enabled for a DWS cluster, this cluster is noncompliant. |
elb-http-to-https-redirection-check |
elb |
If an HTTP listener does not have redirecting requests to an HTTPS listener enabled, this HTTP listener is noncompliant. |
elb-tls-https-listeners-only |
elb |
If any listener of a load balancer does not have the frontend protocol set to HTTPS, this load balancer is noncompliant. |
gaussdb-instance-ssl-enable |
gaussdb |
If a GaussDB instance does not have SSL enabled, this instance is noncompliant. |
gaussdb-mysql-instance-ssl-enable |
taurusdb |
If a TaurusDB instance does not have SSL enabled, this instance is noncompliant. |
obs-bucket-ssl-requests-only |
obs |
If an OBS bucket allows HTTP requests, this bucket is noncompliant. |
rds-instance-ssl-enable |
rds |
If SSL is not enabled for an RDS instance, this instance is noncompliant. |
