Help Center/ Config/ User Guide/ Conformance Packages/ Conformance Package Templates/ Conformance Package for Huawei Cloud Security Configuration Guide (Level 1)
Updated on 2025-02-06 GMT+08:00
This section describes the background, applicable scenarios, and the conformance package to meet requirements of Huawei Cloud Security Configuration Guide at level 1.
Applicable Scenario
Huawei Cloud Security Configuration Guide provides you with baseline configuration guidance for important cloud services. For more details, see Security.
Exemption Clauses
This package provides you with general guide to help you quickly create scenario-based conformance packages. The conformance package and rules included only apply to cloud service and do not represent any legal advice. This conformance package does not ensure compliance with specific laws, regulations, or industry standards. You are responsible for the compliance and legality of your business and technical operations and assume all related responsibilities.
Rules
The guideline No in the following table are in consistent with the chapter No in Huawei Cloud Security Configuration Guide.
Table 1 Rules in the conformance package
Guideline No.
Guideline Description
Rule
Cloud Service
C.CS.FOUNDATION.G_1.R_1
Ensuring that AK/SK are disabled for Administrator Account
iam-root-access-key-check
iam
If the account root user has an available access key, the account is noncompliant.
C.CS.FOUNDATION.G_1.R_2
Enabling MFA for the administrator account
root-account-mfa-enabled
iam
If the root user does not have MFA enabled, this root user is noncompliant.
C.CS.FOUNDATION.G_1.R_14
Ensuring that no iam policy is created to allow the *:* permissions
iam-policy-no-statements-with-admin-access
iam
If a custom policy or role allows all actions (with the action element set to *:*:*, *:*, or *) for all cloud services, this policy or role is noncompliant.
C.CS.FOUNDATION.G_2.R_1
Enabling CTS
multi-region-cts-tracker-exists
cts
If there are no enabled CTS trackers in any of the specified regions, the current account is noncompliant.
C.CS.FOUNDATION.G_2.R_15
Enabling log file integrity verification
cts-support-validate-check
cts
If a CTS tracker does not have trace file verification enabled, this tacker is noncompliant.
C.CS.FOUNDATION.G_3_3.R_1
Disabling the kubernetes cluster versions that has reached EOS
cce-cluster-end-of-maintenance-version
cce
If the version of a CCE cluster is no longer supported for maintenance, this cluster is noncompliant.
C.CS.FOUNDATION.G_3_3.R_6
Preventing cluster nodes from being exposed to public networks
cce-endpoint-public-access
cce
If a CCE cluster has an EIP attached, this CCE cluster is noncompliant.
C.CS.FOUNDATION.G_4.R_1
Disabling internet access over SSH
vpc-sg-restricted-ssh
vpc
If a security group allows all inbound traffic (with the source address set to 0.0.0.0/0 or ::/0) and opens the TCP 22 port, this security group is noncompliant.
C.CS.FOUNDATION.G_4.R_4
Disabling access to remote management ports and high-risk ports over the source IP address 0.0.0.0/0 for security groups
vpc-sg-restricted-common-ports
vpc
If a security group allows all IPv4 and IPv6 traffic (with the source address set to 0.0.0.0/0 or ::/0) to the specified ports, this security group is noncompliant.
C.CS.FOUNDATION.G_5_1.R_2
Disabling anonymous access
obs-bucket-policy-not-more-permissive
obs
If an OBS bucket has a policy that allows more permissions than the specified policy, this bucket is noncompliant.
C.CS.FOUNDATION.G_5_1.R_5
Using bucket policies to restrict access to obs buckets using HTTPS
obs-bucket-ssl-requests-only
obs
If an OBS bucket allows HTTP requests, this bucket is noncompliant.
C.CS.FOUNDATION.G_6_1.R_1
Enabling encrypted communication
rds-instance-ssl-enable
rds
If SSL is not enabled for an RDS instance, this instance is noncompliant.
C.CS.FOUNDATION.G_6_1.R_5
Do not bind an eip to access rds for mysql through internet
rds-instance-no-public-ip
rds
If an RDS instance has an EIP attached, this RDS instance is noncompliant.
C.CS.FOUNDATION.G_6_2.R_1
dds-instance-enable-ssl
dds
If SSL is not enabled for a DDS instance, this instance is noncompliant.
C.CS.FOUNDATION.G_6_2.R_7
Do not use the default port
dds-instance-port-check
dds
If a DDS instance has unallowed ports enabled, this instance is noncompliant.
C.CS.FOUNDATION.G_6_2.R_8
Patch upgrade
dds-instance-engine-version-check
dds
If the version of a DDS instance is earlier than the specified version, this instance is noncompliant.
C.CS.FOUNDATION.G_6_3.R_2
Enabling the backup function and configuring a backup policy
rds-instance-enable-backup
rds
If backup is not enabled for an RDS instance, this instance is noncompliant.
C.CS.FOUNDATION.G_6_3.R_4
rds-instance-port-check
rds
If an RDS instance has unallowed ports enabled, this instance is noncompliant.
C.CS.FOUNDATION.G_6_3.R_8
Update the database version to the latest version
rds-instance-engine-version-check
rds
If the version of an RDS instance engine is earlier than the specified version, this instance is noncompliant.
C.CS.FOUNDATION.G_7_2.R_1
Enabling kerberos authentication
mrs-cluster-kerberos-enabled
mrs
If an MRS cluster does not have Kerberos authentication enabled, this cluster is noncompliant.
C.CS.FOUNDATION.G_7_2.R_3
EIP security group management and control
mrs-cluster-no-public-ip
mrs
If an MRS cluster has an EIP attached, this cluster is noncompliant.
mrs-cluster-in-vpc
mrs
If an MRS cluster is not in the specified VPC, this cluster is noncompliant.
C.CS.FOUNDATION.G_7_3.R_6
Enabling SSL encrypted transmission
dws-enable-ssl
dws
If SSL is not enabled for a DWS cluster, this cluster is noncompliant.
C.CS.FOUNDATION.G_8.R_1
Enabling WAF
waf-instance-enable-protect
waf
If domain name protection is not enabled for a WAF instance, this instance is noncompliant.
C.CS.FOUNDATION.G_8.R_2
Configuring a geolocation access rule in WAF
waf-policy-enable-geoip
waf
If there is a WAF protection policy that does not have geolocation access control configured or enabled, the current account is noncompliant.
C.CS.FOUNDATION.G_8.R_5
Enabling WAF basic web protection block mode
waf-instance-enable-block-policy
waf
If a WAF instance does not have a block policy associated, this instance is noncompliant.
C.CS.FOUNDATION.G_8.R_7
Enabling HSS (basic/professional/enterprise/premium edition)
ecs-attached-hss-agents-check
ecs
If an ECS does not have an HSS agent installed or the protection mode enabled, this ECS is noncompliant.
