Updated on 2025-01-20 GMT+08:00
Best Practices for GaussDB
The following table describes the compliance rules and solutions in the sample template.
Table 1 Conformance package description
Rule
Cloud Service
gaussdb-instance-enable-auditLog
gaussdb
If a GaussDB instance does not have audit log collection enabled, this instance is noncompliant.
gaussdb-instance-enable-backup
gaussdb
If a GaussDB instance does not have the backup enabled, this instance is noncompliant.
gaussdb-instance-enable-errorLog
gaussdb
If a GaussDB instance does not have error log collection enabled, this instance is noncompliant.
gaussdb-instance-enable-slowLog
gaussdb
If a GaussDB instance does not have slow query log collection enabled, this instance is noncompliant.
gaussdb-instance-in-vpc
gaussdb
If a GaussDB instance is not in the specified VPC, this instance is noncompliant.
gaussdb-instance-multiple-az-check
gaussdb
If a GaussDB instance does not support cross-AZ deployment, this instance is noncompliant.
gaussdb-instance-no-public-ip-check
gaussdb
If a GaussDB instance has an EIP attached, this instance is noncompliant.
gaussdb-instance-ssl-enable
gaussdb
If a GaussDB instance does not have SSL enabled, this instance is noncompliant.
