Best Practices for API Gateway
The following table describes the compliance rules and solutions in the sample template.
       Rule  |
       Cloud Service  |
       Description  |
       apig-instances-authorization-type-configured  |
       apig  |
       If a dedicated APIG gateway does not have any types of API authentication configured, this gateway is non-compliant.  |
       apig-instances-execution-logging-enabled  |
       apig  |
       If logging is not enabled for a dedicated APIG gateway, this gateway is considered non-compliant.  |
       apig-instances-ssl-enabled  |
       apig  |
       If no SSL certificates are attached to a dedicated APIG gateway, this gateway is considered noncompliant.  |
