Architecture Security Best Practices
The following table describes the compliance rules and solutions in the sample template.
Rule |
Cloud Service |
Description |
access-keys-rotated |
iam |
If an IAM user's access key is not rotated within the specified number of days, this user is noncompliant. |
pca-certificate-authority-expiration-check |
pca |
If the validity period of a private CA is not within the specified period, this CA is noncompliant. |
pca-certificate-expiration-check |
pca |
apig-instances-execution-logging-enabled |
apig |
If logging is not enabled for a dedicated APIG gateway, this gateway is considered non-compliant. |
apig-instances-ssl-enabled |
apig |
If no SSL certificates are attached to an APIG gateway, this gateway is considered noncompliant. |
cts-lts-enable |
cts |
If a CTS tracker does not have trace transfer to LTS enabled, this tracker is noncompliant. |
cts-kms-encrypted-check |
cts |
If a CTS tracker is not encrypted using KMS, this tracker is noncompliant. |
cts-support-validate-check |
cts |
If a CTS tracker does not have trace file verification enabled, this tacker is noncompliant. |
cts-obs-bucket-track |
cts |
If there are no CTS trackers created for the specified OBS bucket, the current account is noncompliant. |
ecs-multiple-public-ip-check |
ecs |
If an ECS has multiple EIPs attached, this ECS is noncompliant. |
ecs-instance-no-public-ip |
ecs |
If an ECS has an EIP attached, this ECS is noncompliant. |
stopped-ecs-date-diff |
ecs |
If an ECS has been stopped for longer than the time allowed, and no operations have been performed on it, this ECS is noncompliant. |
evs-use-in-specified-days |
evs |
If an EVS disk has not been attached to any resources within the specified number of days after being created, this disk is noncompliant. |
volume-unused-check |
evs |
If an EVS disk is not mounted to any cloud server, this disk is noncompliant. |
cce-cluster-end-of-maintenance-version |
cce |
If the version of a CCE cluster is no longer supported for maintenance, this cluster is noncompliant. |
cce-cluster-oldest-supported-version |
cce |
If a CCE cluster is running the oldest supported version, this cluster is noncompliant. |
sfsturbo-encrypted-check |
sfsturbo |
If KMS encryption is not enabled for an SFS Turbo file system, this file system is noncompliant. |
css-cluster-in-vpc |
css |
If a CSS cluster is not in the specified VPCs, this cluster is noncompliant. |
css-cluster-disk-encryption-check |
css |
If disk encryption is not enabled for a CSS cluster, this cluster is noncompliant. |
elb-tls-https-listeners-only |
elb |
If any listener of a load balancer does not have the frontend protocol set to HTTPS, this load balancer is noncompliant. |
mrs-cluster-kerberos-enabled |
mrs |
If kerberos is not enabled for an MRS cluster, this cluster is noncompliant. |
mrs-cluster-no-public-ip |
mrs |
If an MRS cluster has an EIP attached, this cluster is noncompliant. |
volumes-encrypted-check |
ecs, evs |
If a mounted EVS disk is not encrypted, this disk is noncompliant. |
iam-customer-policy-blocked-kms-actions |
iam, access-analyzer-verified |
If an IAM policy allows any blocked actions on KMS keys, this policy is noncompliant. |
iam-group-has-users-check |
iam |
If an IAM user group has no user, this user group is noncompliant. |
iam-password-policy |
iam |
If the password of an IAM user does not meet the password strength requirements, this IAM user is noncompliant. |
iam-policy-no-statements-with-admin-access |
iam |
If a custom policy or role allows all actions (with the action element set to *:*:*, *:*, or *) for all cloud services, this policy or role is noncompliant. |
iam-role-has-all-permissions |
iam |
If a custom policy or role allows all actions for a cloud service, this policy or role is noncompliant. |
iam-root-access-key-check |
iam |
If the account root user has an available access key, the account is noncompliant. |
iam-user-group-membership-check |
iam |
If an IAM user is not in any of the specified IAM user groups, this user is noncompliant. |
iam-user-mfa-enabled |
iam |
If multi-factor authentication is not enabled for an IAM user, this user is noncompliant. |
iam-user-last-login-check |
iam |
If an IAM user does not log in to the system within the specified time range, this user is non-compliant. |
vpc-sg-restricted-ssh |
vpc |
If a security group allows all inbound traffic (with the source address set to 0.0.0.0/0 or ::/0) and opens the TCP 22 port, this security group is noncompliant. |
ecs-instance-in-vpc |
ecs, vpc |
If an ECS is not within the specified VPC, this ECS is noncompliant. |
kms-not-scheduled-for-deletion |
kms |
If a KMS key is scheduled for deletion, this key is noncompliant. |
function-graph-public-access-prohibited |
fgs |
If a function can be accessed over a public network, this function is noncompliant. |
function-graph-inside-vpc |
fgs |
If a function is not in the specified VPC, this function is noncompliant. |
mfa-enabled-for-iam-console-access |
iam |
If an IAM user who is allowed to access Huawei Cloud console does not have MFA enabled, this IAM user is noncompliant. |
css-cluster-https-required |
css |
If a CSS cluster does not have HTTPS enabled, this cluster is noncompliant. |
rds-instance-no-public-ip |
rds |
If an RDS instance has an EIP attached, this RDS instance is noncompliant. |
rds-instance-logging-enabled |
rds |
If an RDS instance does not have the collection of any types of logs enabled, this instance is noncompliant. |
rds-instances-enable-kms |
rds |
If KMS encryption is not enabled for an RDS instance, this instance is noncompliant. |
dws-enable-kms |
dws |
If KMS encryption is not enabled for a DWS cluster, this cluster is noncompliant. |
gaussdb-nosql-enable-disk-encryption |
gemini db |
If a GeminiDB instance does not have disk encryption enabled, this instance is noncompliant. |
dws-enable-ssl |
dws |
If SSL is not enabled for a DWS cluster, this cluster is noncompliant. |
vpc-sg-restricted-common-ports |
vpc |
If a security group allows all IPv4 and IPv6 traffic (with the source address set to 0.0.0.0/0 or ::/0) to the specified ports, this security group is noncompliant. |
root-account-mfa-enabled |
iam |
If the root user does not have MFA enabled, this root user is noncompliant. |
vpc-default-sg-closed |
vpc |
If a default security group allows all inbound or outbound traffic, this security group is noncompliant. |
vpc-flow-logs-enabled |
vpc |
If a VPC does not have the flow log enabled, this VPC is noncompliant. |
vpc-acl-unused-check |
vpc |
If a network ACL is not attached to any subnets, this ACL is noncompliant. |
vpc-sg-ports-check |
vpc |
If a security group has the source address set to 0.0.0.0/0 or ::/0 and opens all TCP/UDP ports, this security group is noncompliant. |
waf-instance-policy-not-empty |
waf |
If a WAF instance does not have a protection policy attached, this instance is noncompliant. |
pca-certificate-authority-root-disable |
pca |
If private root CAs are not disabled, this rule is noncompliant. |
