Updated on 2025-12-04 GMT+08:00
Conformance Package for Healthcare Industry
The following table describes the compliance rules and solutions in the sample template.
Table 1 Conformance package description
Rule Identifier
Cloud Service
apig-instances-execution-logging-enabled
apig
If logging is not enabled for a dedicated APIG gateway, this gateway is considered non-compliant.
apig-instances-ssl-enabled
apig
If no SSL certificates are attached to a dedicated APIG gateway, this gateway is considered noncompliant.
as-group-elb-healthcheck-required
as
If an AS group is not using Elastic Load Balancing health check, this rule is noncompliant.
css-cluster-disk-encryption-check
css
If disk encryption is not enabled for a CSS cluster, this cluster is noncompliant.
css-cluster-https-required
css
If HTTPS is not enabled for a CSS cluster, this cluster is noncompliant.
css-cluster-in-vpc
css
If a CSS cluster is not in the specified VPCs, this cluster is noncompliant.
cts-kms-encrypted-check
cts
If a CTS tracker is not encrypted using KMS, this tracker is noncompliant.
cts-lts-enable
cts
If Transfer to LTS is not enabled for a CTS tracker, this tracker is noncompliant.
cts-obs-bucket-track
cts
If no CTS trackers are created for the specified OBS bucket, this rule is noncompliant.
cts-support-validate-check
cts
If Verify Trace File is not enabled for a CTS tracker, this tacker is noncompliant.
cts-tracker-exists
cts
If there is no tracker in the current account, this rule is noncompliant
drs-data-guard-job-not-public
drs
If the network type of a DR task is set to public network, this DR task is noncompliant.
drs-migration-job-not-public
drs
If the network type of a migration task is set to public network, this migration task is noncompliant.
drs-synchronization-job-not-public
drs
If the network type of a synchronization task is not set to public network, this task is noncompliant.
dws-enable-log-dump
dws
If a DWS cluster does not have log transfer enabled, this cluster is noncompliant.
dws-enable-snapshot
dws
If automated snapshots are not enabled for a DWS cluster, this cluster is noncompliant.
dws-enable-ssl
dws
If SSL is not enabled for a DWS cluster, this cluster is noncompliant.
ecs-instance-in-vpc
ecs, vpc
If an ECS is not within the specified VPC, this ECS is noncompliant.
ecs-instance-no-public-ip
ecs
If an ECS has an EIP attached, this ECS is noncompliant.
eip-unbound-check
vpc
If an EIP has not been attached to any resource, this EIP is noncompliant.
eip-use-in-specified-days
eip
If an EIP is not used within the specified number of days after being created, the EIP is noncompliant.
elb-predefined-security-policy-https-check
elb
If a specified security policy is not configured for the HTTPS listener of a dedicated load balancer, this dedicated load balancer is noncompliant.
elb-tls-https-listeners-only
elb
If any listener of a load balancer does not have the frontend protocol set to HTTPS, this load balancer is noncompliant.
function-graph-public-access-prohibited
fgs
If a function can be accessed over a public network, this function is noncompliant.
gaussdb-nosql-enable-backup
gaussdb nosql
If the backup is not enabled for a GeminiDB instance, this instance is noncompliant.
gaussdb-nosql-enable-disk-encryption
gaussdb nosql
If Disk Encryption is disabled for a GeminiDB instance, this instance is noncompliant.
iam-customer-policy-blocked-kms-actions
iam
If there is a blocked action for KMS in an IAM policy, this policy is noncompliant.
iam-password-policy
iam
If the password of an IAM user does not meet the password strength requirements, this IAM user is noncompliant.
iam-policy-no-statements-with-admin-access
iam
If an IAM policy grants administrator permissions (with the Action element set to *:*:*, *:*, or *), this policy is noncompliant.
iam-role-has-all-permissions
iam
If an IAM custom policy contains *:* in the allow section, this policy is noncompliant.
iam-root-access-key-check
iam
If the account root user has an available access key, the account is noncompliant.
iam-user-last-login-check
iam
If an IAM user does not log in to the system within the specified time range, this user is non-compliant.
iam-user-mfa-enabled
iam
If multi-factor authentication is not enabled for an IAM user, this user is noncompliant.
kms-not-scheduled-for-deletion
kms
If a KMS key is scheduled for deletion, this key is noncompliant.
mfa-enabled-for-iam-console-access
iam
If MFA is not enabled for an IAM user who has a console password, this IAM user is noncompliant.
mrs-cluster-kerberos-enabled
mrs
If kerberos is not enabled for an MRS cluster, this cluster is noncompliant.
mrs-cluster-no-public-ip
mrs
If an MRS cluster has an EIP attached, this cluster is noncompliant.
multi-region-cts-tracker-exists
cts
If there are no CTS trackers in any of the specified regions, this rule is noncompliant.
pca-certificate-authority-expiration-check
pca
If the validity period of a private CA is not within the specified period, this CA is noncompliant.
pca-certificate-expiration-check
pca
If the validity period of a certificate is not within the specified range, this certificate is noncompliant.
private-nat-gateway-authorized-vpc-only
nat
If a private NAT gateway is not in a specified VPC, this gateway is noncompliant.
rds-instance-enable-backup
rds
If backup is not enabled for an RDS instance, this instance is noncompliant.
rds-instance-multi-az-support
rds
If an RDS instance does not support multi-AZ deployment, this RDS instance is noncompliant.
rds-instance-no-public-ip
rds
If an RDS instance has an EIP attached, this RDS instance is noncompliant.
rds-instances-enable-kms
rds
If KMS encryption is not enabled for an RDS instance, this instance is noncompliant.
root-account-mfa-enabled
iam
If multi-factor authentication is not enabled for the root user, the root user is noncompliant.
sfsturbo-encrypted-check
sfsturbo
If KMS encryption is not enabled for an SFS Turbo file system, this file system is noncompliant.
stopped-ecs-date-diff
ecs
If an ECS has been stopped for longer than the time allowed, and no operations have been performed on it, this ECS is noncompliant.
volumes-encrypted-check
ecs, evs
If a mounted EVS disk is not encrypted, this disk is noncompliant.
vpc-acl-unused-check
vpc
If a network ACL is not attached to any subnets, this ACL is noncompliant.
vpc-default-sg-closed
vpc
If a default security group allows all inbound or outbound traffic, this security group is noncompliant.
vpc-flow-logs-enabled
vpc
If there is a flow log that has not been enabled for a VPC, this VPC is noncompliant.
vpc-sg-ports-check
vpc
If a security group allows all inbound traffic (with the source address set to 0.0.0.0/0) and opens all TCP/UDP ports, this security group is noncompliant.
vpc-sg-restricted-common-ports
vpc
If a security group allows all IPv4 addresses (0.0.0.0/0) to access a specified port, this security group is noncompliant.
vpc-sg-restricted-ssh
vpc
If the source address is set to 0.0.0.0/0 and the TCP port 22 is opened, this security group is non-compliant.
vpn-connections-active
vpnaas
If a VPN is not normally connected, this rule is noncompliant.
