Updated on 2025-10-13 GMT+08:00
Conformance Package for PCI DSS
This section describes the background, applicable scenarios, and the conformance package to meet requirements of the Payment Card Industry Data Security Standard (PCI-DSS).
Background
PCI DSS is an information security standard for safe payments worldwide. PCI DSS contains technical and operational baselines to ensure data security of paying accounts. Although specifically designed to focus on environments with payment card account data, PCI DSS can also help reduce payment threats and protect the people, processes, and technologies across the payment ecosystem. For more information about PCI DSS, see Payment Card Industry (PCI) Data Security Standard.
Applicable Scenarios
This conformance package helps enterprises meet PCI DSS and legal requirements for safe card payments. It needs to be reviewed and implemented based on specific conditions.
Exemption Clauses
This package provides you with general guide to help you quickly create scenario-based conformance packages. The conformance package and rules included only apply to cloud service and do not represent any legal advice. This conformance package does not ensure compliance with specific laws, regulations, or industry standards. You are responsible for the compliance and legality of your business and technical operations and assume all related responsibilities.
Rules
The guideline numbers in the following table are in consistent with the chapter numbers in Payment Card Industry (PCI) Data Security Standard.
Table 1 Rules in the conformance package
Guideline No.
Guideline Description
Rule
Solution
1.3
Prohibit direct public access between the Internet and any system component in the cardholder data environment.
css-cluster-in-vpc
Deploy all CSS clusters within VPCs.
1.3
css-cluster-in-vpc
1.3
drs-data-guard-job-not-public
Block public access to DRS real-time DR tasks.
1.3
drs-migration-job-not-public
Block public access to DRS real-time migration tasks.
1.3
drs-synchronization-job-not-public
Block public access to DRS real-time synchronization tasks.
1.3
ecs-instance-in-vpc
Deploy all ECSs within VPCs.
1.3
ecs-instance-no-public-ip
Block public access to ECSs to protect data.
1.3
function-graph-inside-vpc
Configure VPC access for all functions using the FunctionGraph service.
1.3
function-graph-public-access-prohibited
Block public access to FunctionGraph functions. Public access may affect resource availability.
1.3
mrs-cluster-no-public-ip
Block public access to MRS clusters. MRS instances may contain sensitive information, and access control is required.
1.3
rds-instance-no-public-ip
Block access to RDS instances over public networks. RDS instances may contain sensitive information, and access control is required.
1.3
vpc-default-sg-closed
Use security groups to control access within a VPC. You can directly use the default security group for resource access control.
1.3
vpc-sg-ports-check
You can use security groups to control port connections.
1.3
vpc-sg-restricted-common-ports
You can configure security groups to control connections to frequently used ports.
1.3
vpc-sg-restricted-ssh
You can configure security groups to only allow traffic from some IPs to access the SSH port 22 of ECSs to ensure secure remote access to ECSs.
2.1
Always change vendor-supplied defaults and remove or disable unnecessary default accounts before installing a system on the network. This applies to ALL default passwords, including but not limited to those used by operating systems, software that provides security services, application and system accounts, point-of-sale (POS) terminals, payment applications, Simple Network Management Protocol (SNMP) community strings, etc.
root-account-mfa-enabled
Enable MFA for root users. MFA provides additional protection to login credentials.
2.1
2.2
Develop configuration standards for all system components. Assure that these standards address all known security vulnerabilities and are consistent with industry-accepted system hardIPng standards. Sources of industry-accepted system hardIPng standards may include, but are not limited to: Center for Internet Security (CIS), International Organization for Standardization (ISO), SysAdmin Audit Network Security (SANS), and Institute National Institute of Standards Technology (NIST).
access-keys-rotated
Enable key rotation.
2.2
Develop configuration standards for all system components. Assure that these standards address all known security vulnerabilities and are consistent with industry-accepted system hardening standards. Sources of industry-accepted system hardIPng standards may include, but are not limited to: Center for Internet Security (CIS), International Organization for Standardization (ISO), SysAdmin Audit Network Security (SANS), and Institute National Institute of Standards Technology (NIST).
access-keys-rotated
2.2
cts-kms-encrypted-check
Enable trace file encryption for CTS trackers.
2.2
cts-lts-enable
Enable Transfer to LTS for CTS trackers.
2.2
Develop configuration standards for all system components. Assure that these standards address all known security vulnerabilities and are consistent with industry-accepted system hardening standards. Sources for guidance on configuration standards include but are not limited to: Center for Internet Security (CIS), International Organization for Standardization (ISO), National Institute of Standards and Technology (NIST), Cloud Security Alliance, and product vendors.
cts-obs-bucket-track
Create at least one CTS tracker for each OBS bucket.
2.2
cts-support-validate-check
You can enable file verification for CTS trackers to prevent log files from being modified or deleted after being stored.
2.2
ecs-in-allowed-security-groups
Use security groups to control access to ECSs. The rules of a security group will apply to all ECSs that are added to this security group.
2.2
ecs-multiple-public-ip-check
You can use this rule to identify ECSs that have multiple EIPs attached to reduce network security risks.
2.2
iam-policy-no-statements-with-admin-access
Grant IAM users only necessary permissions for performing specific operations. Granting users more permissions than they need may violate the principles of least privilege and separation of duties.
2.2
iam-root-access-key-check
2.2
iam-user-group-membership-check
Ensure each user is in at least one user group for permission management. Granting users more permissions than they need may violate the principles of least privilege and separation of duties.
2.2
kms-rotation-enabled
Enable KMS key rotation.
2.2
mfa-enabled-for-iam-console-access
Enable MFA for all IAM users who can access Huawei Cloud management console. MFA enhances account security to prevent account theft and protect sensitive data.
2.2
multi-region-cts-tracker-exists
Create CTS trackers for different regions where your services are deployed. When you enable CTS for the first time, a management tracker, system, is created automatically. You can create multiple trackers for different regions to help make services better satisfy customer needs as well as legal or regulatory requirements.
2.2
2.2
volumes-encrypted-check
Enable encryption for all EVS disks to protect data.
2.2
2.2
vpc-flow-logs-enabled
Enable flow logs for VPCs to help monitor network traffic, analyze network attacks, and optimize security group and ACL configurations.
2.2
2.2
You can configure security groups to restrict connections to SSH port 23.
2.3
Encrypt all non-console administrative access using strong cryptography.
apig-instances-ssl-enabled
Enable SSL for APIG REST APIs to authenticate API Gateway requests.
2.3
css-cluster-https-required
HTTPS enables encrypted communication with clusters. If HTTPS is disabled, HTTP is used. This compromises data security, and public access cannot be enabled.
2.3
dws-enable-ssl
Enable SSL for DWS clusters to protect data.
2.3
elb-tls-https-listeners-only
Ensure that your load balancer listeners are configured with the HTTPS protocol.
2.4
Maintain an inventory of system components that are in scope for PCI DSS.
Use security groups to control access to ECSs. The rules of a security group will apply to all ECSs that are added to this security group. You can also associate more strict security groups to specific ECSs.
2.4
eip-unbound-check
Ensure that there are no unattached EIPs.
2.4
eip-use-in-specified-days
2.4
vpc-acl-unused-check
Use this rule to identity unattached ACLs. An ACL helps control traffic in and out of a subnet.
3.4
Render PAN unreadable anywhere it is stored (including on portable digital media, backup media, and in logs) by using any of the following approaches: one-way hashes based on strong cryptography (hash must be of the entire PAN), truncation (hashing cannot be used to replace the truncated segment of PAN), index tokens and pads (pads must be securely stored), and strong cryptography with associated key-management processes and procedures. Note: It is a relatively trivial effort for a malicious individual to reconstruct original PAN data if they have access to both the truncated and hashed version of a PAN. Where hashed and truncated versions of the same PAN are present in an entity's environment, additional controls must be in place to ensure that the hashed and truncated versions cannot be correlated to reconstruct the original PAN.
3.4
Render PAN unreadable anywhere it is stored (including on portable digital media, backup media, and in logs) by using any of the following approaches: One-way hashes based on strong cryptography (hash must be of the entire PAN), truncation (hashing cannot be used to replace the truncated segment of PAN), index tokens and pads (pads must be securely stored), and strong cryptography with associated key-management processes and procedures. Note: It is a relatively trivial effort for a malicious individual to reconstruct original PAN data if they have access to both the truncated and hashed version of a PAN. Where hashed and truncated versions of the same PAN are present in an entity's environment, additional controls must be in place to ensure that the hashed and truncated versions cannot be correlated to reconstruct the original PAN.
rds-instances-enable-kms
Enable KMS encryption for RDS instances to protect data.
3.4
sfsturbo-encrypted-check
Enable KMS encryption for SFS Turbo file systems.
3.4
Enable encryption for EVS to protect data.
4.1
Use strong cryptography and security protocols to safeguard sensitive cardholder data during transmission over open, public networks, including the following: Only trusted keys and certificates are accepted. The protocol in use only supports secure versions or configurations. The encryption strength is appropriate for the encryption methodology in use. Examples of open, public networks include but are not limited to: The Internet Wireless technologies, including 802.11 and Bluetooth Cellular technologies, for example, Global System for Mobile communications (GSM), code division multiple access (CDMA), General Packet Radio Service (GPRS), and satellite communications.
Enable SSL for API Gateway REST APIs to authenticate API requests.
4.1
css-cluster-disk-encryption-check
Enable disk encryption for CSS clusters to protect data.
4.1
Enable disk encryption for CSS clusters to protect sensitive data.
4.1
4.1
dws-enable-ssl
4.1
4.1
pca-certificate-authority-expiration-check
Use Private Certificate Authority (PCA) to create and manage your private CAs and ensure that there are no expired certificates.
4.1
pca-certificate-expiration-check
6.2
Ensure that all system components and software are protected from known vulnerabilities by installing applicable vendor- supplied security patches. Install critical security patches within one month of release. Note: Critical security patches should be identified according to the risk ranking process defined in Requirement 6.1.
cce-cluster-end-of-maintenance-version
Ensure that CCE cluster versions can be maintained.
6.2
cce-cluster-oldest-supported-version
Ensure that there are no CCE cluster versions that cannot be maintained. For CCE clusters of supported versions, The system automatically deploys security patches to upgrade your CCE clusters. If any security issue is identified, Huawei Cloud will fix the issue.
10.1
Implement audit trails to link all access to system components to each individual user.
apig-instances-execution-logging-enabled
Enable CTS for your dedicated APIG gateways. APIG supports custom log analysis templates, which you can use to collect and manage logs and trace and analyze API request exceptions.
10.1
10.1
cts-tracker-exists
Ensure that a CTS tracker has been created for your account to record operations on the Huawei Cloud management console.
10.1
Ensure that there are CTS trackers in regions where your services are deployed. Cloud Trace Service (CTS) allows you to collect, store, and query operation records of cloud resources. When you enable CTS for the first time, a management tracker, system, is created automatically. You can create multiple trackers.
10.1
10.5
Secure audit trails so they cannot be altered.
11.5
Deploy a change-detection mechanism (for example, file-integrity monitoring tools) to alert personnel to unauthorized modification (including changes, additions, and deletions) of critical system files, configuration files, or content files; and configure the software to perform critical file comparisons at least weekly.
1.2.1
Restrict inbound and outbound traffic to that which is necessary for the cardholder data environment, and specifically deny all other traffic.
css-cluster-in-vpc
1.2.1
css-cluster-in-vpc
1.2.1
1.2.1
1.2.1
1.2.1
ecs-instance-in-vpc
1.2.1
1.2.1
Deploy FunctionGraph functions within VPCs.
1.2.1
Block public access to FunctionGraph functions. Public access may reduce resource availability.
1.2.1
1.2.1
Block public access to RDS instances. RDS instances may contain sensitive information, and access control is required.
1.2.1
1.2.1
vpc-sg-ports-check
1.2.1
1.2.1
You can configure security groups to restrict connections to SSH port 24.
1.3.1
Implement a DMZ to limit inbound traffic to only system components that provide authorized publicly accessible services, protocols, and ports.
css-cluster-in-vpc
1.3.1
css-cluster-in-vpc
1.3.1
1.3.1
1.3.1
1.3.1
ecs-instance-in-vpc
1.3.1
1.3.1
1.3.1
1.3.1
1.3.1
1.3.1
1.3.1
vpc-sg-ports-check
1.3.1
1.3.1
Configure security groups to restrict connections to SSH port 25.
1.3.2
Limit inbound Internet traffic to IP addresses within the DMZ.
css-cluster-in-vpc
1.3.2
css-cluster-in-vpc
1.3.2
1.3.2
1.3.2
1.3.2
ecs-instance-in-vpc
1.3.2
1.3.2
1.3.2
1.3.2
1.3.2
1.3.2
1.3.2
vpc-sg-ports-check
1.3.2
1.3.2
Configure security groups to restrict connections to SSH port 26.
1.3.4
Do not allow unauthorized outbound traffic from the cardholder data environment to the Internet.
css-cluster-in-vpc
1.3.4
css-cluster-in-vpc
1.3.4
1.3.4
1.3.4
1.3.4
ecs-instance-in-vpc
1.3.4
1.3.4
1.3.4
1.3.4
1.3.4
1.3.4
1.3.4
vpc-sg-ports-check
1.3.4
Configure security groups to control connections to common ports in a VPC.
1.3.4
Configure security groups to restrict connections to SSH port 27.
1.3.6
Place system components that store cardholder data (such as a database) in an internal network zone, segregated from the DMZ and other untrusted networks.
css-cluster-in-vpc
1.3.6
css-cluster-in-vpc
1.3.6
1.3.6
1.3.6
1.3.6
ecs-instance-in-vpc
1.3.6
1.3.6
1.3.6
1.3.6
vpc-sg-ports-check
1.3.6
1.3.6
Configure security groups to restrict connections to SSH port 28.
10.2.1
Implement automated audit trails for all system components to reconstruct the following events: all individual user accesses to cardholder data.
10.2.1
10.2.1
cts-tracker-exists
10.2.1
10.2.2
Implement automated audit trails for all system components to reconstruct the following events: All actions taken by any individual with root or administrative privileges.
cts-tracker-exists
Ensure that a CTS tracker has been created for your account to record operations on the Huawei Cloud console.
10.2.2
10.2.3
Implement automated audit trails for all system components to reconstruct the following events: Access to all audit trails.
10.2.3
cts-tracker-exists
10.2.3
10.2.4
Implement automated audit trails for all system components to reconstruct the following events: Invalid logical access attempts.
Enable CTS for your dedicated API gateways. APIG supports custom log analysis templates, which you can use to collect and manage logs and trace and analyze API request exceptions.
10.2.4
10.2.4
cts-tracker-exists
10.2.4
10.2.5
Implement automated audit trails for all system components to reconstruct the following events: Use of and changes to identification and authentication mechanisms—including but not limited to creation of new accounts and elevation of privileges—and all changes, additions, or deletions to accounts with root or administrative privileges.
cts-tracker-exists
10.2.5
10.2.6
Implement automated audit trails for all system components to reconstruct the following events: Initialization, stopping, or pausing of the audit logs.
cts-tracker-exists
10.2.6
10.2.7
Implement automated audit trails for all system components to reconstruct the following events: Creation and deletion of system-level objects.
10.2.7
cts-tracker-exists
10.2.7
10.3.1
Record at least the following audit trail entries for all system components for each event: User identification.
10.3.1
10.3.1
cts-tracker-exists
10.3.1
10.3.1
10.5.2
Protect audit trail files from unauthorized modifications.
10.5.3
Promptly back up audit trail files to a centralized log server or media that is difficult to alter.
cts-lts-enable
10.5.5
Use file-integrity monitoring or change-detection software on logs to ensure that existing log data cannot be changed without generating alerts (although new data being added should not cause an alert).
2.2.2
Enable only necessary services, protocols, daemons, etc., as required for the function of the system.
2.2.2
2.2.2
2.2.2
ecs-instance-in-vpc
2.2.2
2.2.2
2.2.2
2.2.2
2.2.2
2.2.2
2.2.2
vpc-sg-ports-check
2.2.2
2.2.2
Configure security groups to restrict connections to SSH port 29.
3.5.2
Restrict access to cryptographic keys to the fewest number of custodians necessary.
iam-customer-policy-blocked-kms-actions
Use this rule to identity policies that disable KMS encryption. Granting users more permissions than they need may violate the principles of least privilege and separation of duties.
3.6.4
Cryptographic key changes for keys that have reached the end of their cryptoperiod (for example, after a defined period of time has passed and/or after a certain amount of cipher-text has been produced by a given key), as defined by the associated application vendor or key owner, and based on industry best practices and guidelines (for example, NIST Special Publication 800-57).
3.6.5
Retirement or replacement (for example, archiving, destruction, and/or revocation) of keys as deemed necessary when the integrity of the key has been weakened (for example, departure of an employee with knowledge of a clear-text key component), or keys are suspected of being compromised. Note: If retired or replaced cryptographic keys need to be retained, these keys must be securely archived (for example, by using a key-encryption key). Archived cryptographic keys should only be used for decryption/verification purposes.
kms-not-scheduled-for-deletion
Ensure that there are no KMS keys scheduled for deletion.
3.6.7
Prevention of unauthorized substitution of cryptographic keys.
7.1.1
Define access needs for each role, including: system components and data resources that each role needs to access for their job function and level of privilege required (for example, user, administrator, etc.) for accessing resources.
7.1.1
iam-group-has-users-check
Add IAM users to at least one user group so that users can inherit permissions attached to the user group that they are in.
7.1.1
7.1.1
iam-role-has-all-permissions
Only grant IAM users necessary permissions for performing specific operations. Granting users more permissions than they need may violate the least privilege principle and damage separation of duties.
7.1.1
7.1.1
7.1.1
mrs-cluster-kerberos-enabled
Enable Kerberos for MRS clusters.
7.1.2
Restrict access to privileged user IDs to least privileges necessary to perform job responsibilities.
7.1.2
7.1.2
7.1.2
7.1.2
7.1.2
7.2.1
Establish an access control system that restricts access based on a user's need to know, and is set to "deny all" unless specifically allowed. This access control system(s) must include the following: Coverage of all system components.
7.2.1
7.2.1
7.2.1
7.2.1
7.2.1
Ensure that each user is in at least one user group for permission management. Granting users more permissions than they need may violate the principles of least privilege and separation of duties.
7.2.1
7.2.2
7.2.2
7.2.2
7.2.2
7.2.2
7.2.2
7.2.2
8.1.1
Assign all users a unique ID before allowing them to access system components or cardholder data.
8.1.4
Remove/disable inactive user accounts within 90 days.
access-keys-rotated
8.2.1
Using strong cryptography, render all authentication credentials (such as passwords/phrases) unreadable during transmission and storage on all system components.
8.2.1
8.2.1
Enable KMS for RDS to encrypt data at rest.
8.2.1
8.2.1
8.2.3
Passwords/passphrases must meet the following: Require a minimum length of at least seven characters; only digits and letters are allowed; and alternatively, the complexity and strength of the password/passphrase must be at least comparable to the parameters specified above.
iam-password-policy
Set thresholds for IAM user password strength.
8.2.4
Change user passwords/passphrases at least once every 90 days.
access-keys-rotated
8.2.4
access-keys-rotated
8.2.4
iam-password-policy
8.2.5
Do not allow an individual to submit a new password/passphrase that is the same as any of the last four passwords/passphrases he or she has used.
iam-password-policy
8.3.1
Incorporate multi-factor authentication for all non-console access into the CDE for personnel with administrative access.
iam-user-mfa-enabled
Enable MFA for all IAM users. MFA provides an additional layer of protection in addition to the username and password.
8.3.1
Enable MFA for all IAM users who can access Huawei Cloud management console MFA provides an additional layer of protection in addition to the username and password.
8.3.1
Enable MFA for root users. MFA adds additional protection to login credentials.
8.3.2
8.3.2
Incorporate multi-factor authentication for all remote network access (both user and administrator, and including third-party access for support or maintenance) originating from outside the entity's network.
8.3.2
