Conformance Package for ECS
The following table lists the rules and solutions included in this conformance package template.
Rule |
Cloud Service |
Description |
ecs-instance-key-pair-login |
ecs |
If key pair authentication is not required for ECS logging, this ECS is noncompliant. |
ecs-instance-no-public-ip |
ecs |
If an ECS has an EIP attached, this ECS is noncompliant. |
ecs-multiple-public-ip-check |
ecs |
If an ECS has multiple EIPs attached, this ECS is noncompliant. |
stopped-ecs-date-diff |
ecs |
If an ECS has been stopped for longer than the time allowed, and no operations have been performed on it, this ECS is noncompliant. |
volumes-encrypted-check |
ecs, evs |
If a mounted EVS disk is not encrypted, this disk is noncompliant. |
ecs-attached-hss-agents-check |
ecs |
If an ECS does not have an HSS agent installed or the protection mode enabled, this ECS is noncompliant. |
ecs-instance-agency-attach-iam-agency |
ecs |
If an ECS does not have any IAM agencies attached, this ECS is noncompliant. |
ecs-last-backup-created |
cbr, ecs |
If an ECS does not have a backup created within the specified period, this ECS is noncompliant. |
