On this page
Show all
Help Center/ Config/ User Guide/ Conformance Packages/ Conformance Package Templates/ Conformance Package for Architecture Reliability
Updated on 2025-01-22 GMT+08:00
The following table lists the rules and solutions included in this conformance package template.
Table 1 Conformance package description
Rule Identifier
Cloud Service
apig-instances-execution-logging-enabled
apig
If logging is not enabled for a dedicated APIG gateway, this gateway is considered non-compliant.
as-group-elb-healthcheck-required
as
If an AS group is not using Elastic Load Balancing health check, this rule is noncompliant.
cts-lts-enable
cts
If Transfer to LTS is not enabled for a CTS tracker, this tracker is noncompliant.
cts-obs-bucket-track
cts
If no CTS trackers are created for the specified OBS bucket, this rule is noncompliant.
cts-tracker-exists
cts
If there are no CTS trackers in an account, this account is noncompliant.
dws-enable-kms
dws
If KMS encryption is not enabled for a DWS cluster, this cluster is noncompliant.
ecs-instance-in-vpc
ecs, vpc
If an ECS is not within the specified VPC, this ECS is noncompliant.
function-graph-concurrency-check
fgs
If the number of concurrent requests of a FunctionGraph function is not within the specified range, this function is noncompliant.
gaussdb-nosql-enable-disk-encryption
gaussdb nosql
If a GeminiDB instance does not have disk encryption enabled, this instance is noncompliant.
kms-not-scheduled-for-deletion
kms
If a KMS key is scheduled for deletion, this key is noncompliant.
multi-region-cts-tracker-exists
cts
If there are no trackers in any of the specified regions, this rule is noncompliant.
rds-instance-enable-backup
rds
If backup is not enabled for an RDS instance, this instance is noncompliant.
rds-instance-multi-az-support
rds
If an RDS instance does not support multi-AZ deployment, this RDS instance is noncompliant.
rds-instances-enable-kms
rds
If KMS encryption is not enabled for an RDS instance, this instance is noncompliant.
sfsturbo-encrypted-check
sfsturbo
If KMS encryption is not enabled for an SFS Turbo file system, this file system is noncompliant.
volumes-encrypted-check
ecs, evs
If a mounted EVS disk is not encrypted, this disk is noncompliant.
vpc-flow-logs-enabled
vpc
If there is a flow log that has not been enabled for a VPC, this VPC is noncompliant.
vpn-connections-active
vpnaas
Ensure normal VPN connections.
