Conformance Package for Autopilot
The following table lists the rules and solutions included in this conformance package template.
Rule |
Cloud Service |
Description |
css-cluster-disk-encryption-check |
css |
If disk encryption is not enabled for a CSS cluster, this cluster is noncompliant. |
css-cluster-https-required |
css |
If HTTPS is not enabled for a CSS cluster, this cluster is noncompliant. |
css-cluster-no-public-zone |
css |
If a CSS cluster can be accessed over a public network, this cluster is noncompliant. |
css-cluster-security-mode-enable |
css |
If a CSS cluster does not support the security mode, this cluster is noncompliant. |
cts-kms-encrypted-check |
cts |
If a CTS tracker is not encrypted using KMS, this tracker is noncompliant. |
cts-obs-bucket-track |
cts |
If no CTS trackers are created for the specified OBS bucket, this rule is noncompliant. |
cts-support-validate-check |
cts |
If Verify Trace File is not enabled for a CTS tracker, this tacker is noncompliant. |
cts-tracker-exists |
cts |
If there are no CTS trackers in an account, this account is noncompliant. |
dcs-redis-no-public-ip |
dcs |
If a DCS Redis instance has an EIP associated, this instance is noncompliant. |
dcs-redis-password-access |
dcs |
If a DCS Redis instance can be accessed without a password, this instance is noncompliant. |
ecs-instance-no-public-ip |
ecs |
If an ECS has an EIP attached, this ECS is noncompliant. |
elb-loadbalancers-no-public-ip |
elb |
If a load balancer has an EIP attached, this load balancer is noncompliant. |
elb-tls-https-listeners-only |
elb |
If any listener of a load balancer does not have the frontend protocol set to HTTPS, this load balancer is noncompliant. |
iam-password-policy |
iam |
If the password of an IAM user does not meet the password strength requirements, this IAM user is noncompliant. |
iam-user-last-login-check |
iam |
If an IAM user does not log in to the system within the specified time range, the result is non-compliant. |
iam-user-mfa-enabled |
iam |
If multi-factor authentication is not enabled for an IAM user, this user is noncompliant. |
rds-instance-no-public-ip |
rds |
If an RDS instance has an EIP attached, this RDS instance is noncompliant. |
root-account-mfa-enabled |
iam |
If multi-factor authentication is not enabled for the root user, the root user is noncompliant. |
volumes-encrypted-check |
ecs, evs |
If a mounted EVS disk is not encrypted, this disk is noncompliant. |
vpc-flow-logs-enabled |
vpc |
If there is a flow log that has not been enabled for a VPC, this VPC is noncompliant. |
vpc-sg-ports-check |
vpc |
If a security group allows all inbound traffic (with the source address set to 0.0.0.0/0) and opens all TCP/UDP ports, this security group is noncompliant. |
