Conformance Package for the Financial Industry
The following table lists the rules and solutions included in this conformance package template.
Rule Identifier |
Cloud Service |
Rule Content |
access-keys-rotated |
iam |
If an IAM user's access key is not rotated within the specified number of days, this user is noncompliant. |
as-group-elb-healthcheck-required |
as |
If an AS group is not using Elastic Load Balancing health check, the result is noncompliant. |
css-cluster-https-required |
css |
If HTTPS is not enabled for a CSS cluster, this cluster is noncompliant. |
css-cluster-in-vpc |
css |
If a CSS cluster is not in any of the specified VPCs, this cluster is noncompliant. |
cts-kms-encrypted-check |
cts |
If a CTS tracker is not encrypted using KMS, this tracker is noncompliant. |
cts-lts-enable |
cts |
If Transfer to LTS is not enabled for a CTS tracker, this tracker is noncompliant. |
cts-obs-bucket-track |
cts |
If no CTS trackers are created for the specified OBS bucket, this rule is noncompliant. |
cts-support-validate-check |
cts |
If Verify Trace File is not enabled for a CTS tracker, this tacker is noncompliant. |
cts-tracker-exists |
cts |
If there are no CTS trackers in an account, this account is noncompliant. |
ecs-instance-in-vpc |
ecs, vpc |
If an ECS is not within the specified VPC, this ECS is noncompliant. |
ecs-instance-no-public-ip |
ecs |
If an ECS has a public IP attached, this ECS is noncompliant. |
eip-unbound-check |
vpc |
If an EIP has not been attached to any resource, this EIP is noncompliant. |
elb-tls-https-listeners-only |
elb |
If any listener of a load balancer is not configured with HTTPS, this load balancer is noncompliant. |
function-graph-concurrency-check |
fgs |
If the number of concurrent requests of a FunctionGraph function is not within the specified range, this function is noncompliant. |
iam-group-has-users-check |
iam |
If an IAM user group has no user, this user group is noncompliant. |
iam-password-policy |
iam |
If the password of an IAM user does not meet the password strength requirements, this IAM user is noncompliant. |
iam-root-access-key-check |
iam |
If the account root user has an available access key, the account is noncompliant. |
iam-user-group-membership-check |
iam |
If an IAM user is not in any of the specified IAM user groups, this user is noncompliant. |
iam-user-last-login-check |
iam |
If an IAM user does not log in to the system within the specified time range, the result is non-compliant. |
iam-user-mfa-enabled |
iam |
If multi-factor authentication is not enabled for an IAM user, this user is noncompliant. |
kms-rotation-enabled |
kms |
If key rotation is not enabled for a KMS key, this key is noncompliant. |
mfa-enabled-for-iam-console-access |
iam |
If MFA is not enabled for an IAM user who has a console password, this IAM user is noncompliant. |
mrs-cluster-in-vpc |
mrs |
If an MRS cluster is not in the specified VPC, this cluster is noncompliant. |
mrs-cluster-kerberos-enabled |
mrs |
If kerberos is not enabled for an MRS cluster, this cluster is noncompliant. |
mrs-cluster-no-public-ip |
mrs |
If an MRS cluster has an EIP attached, this cluster is noncompliant. |
private-nat-gateway-authorized-vpc-only |
nat |
If a private NAT gateway is not in a specified VPC, this gateway is noncompliant. |
rds-instance-multi-az-support |
rds |
If an RDS instance does not support multi-AZ deployment, this RDS instance is noncompliant. |
rds-instance-no-public-ip |
rds |
If an RDS instance has an EIP attached, this RDS instance is noncompliant. |
root-account-mfa-enabled |
iam |
If multi-factor authentication is not enabled for the root user, the root user is noncompliant. |
stopped-ecs-date-diff |
ecs |
If an ECS has been stopped for longer than the time allowed, and no operations have been performed on it, this ECS is noncompliant. |
volume-unused-check |
evs |
If an EVS disk is not mounted to any cloud server, this disk is noncompliant. |
volumes-encrypted-check |
ecs, evs |
If a mounted EVS disk is not encrypted, this disk is noncompliant. |
vpc-acl-unused-check |
vpc |
If a network ACL is not attached to any subnets, this ACL is noncompliant. |
vpc-flow-logs-enabled |
vpc |
If there is a flow log that has not been enabled for a VPC, this VPC is noncompliant. |
vpc-sg-ports-check |
vpc |
If a security group allows all inbound traffic (with the source address set to 0.0.0.0/0) and opens all TCP/UDP ports, this security group is noncompliant. |
vpn-connections-active |
vpnaas |
If a VPN is not normally connected, this rule is noncompliant. |
waf-instance-policy-not-empty |
waf |
If a WAF instance does not have a protection policy attached, this instance is noncompliant. |
