Deleting an Organization Conformance Package
If you do not need an organization conformance package any longer, you can follow the procedure below to delete it.
- Log in to the management console as an organization administrator or a delegated administrator of Config.
- Click
in the upper left corner of the page. Under Management & Governance, select Config.
- On the left navigation pane, choose Conformance Package.
- Select the Organizational Conformance Package tab. In the list, locate a target package and click Delete in the Operation column.
After an organization conformance package is deleted, the package is also automatically deleted from the package lists of the member accounts.
Figure 1 Deleting an organization conformance package
