Help Center/ Config/ User Guide/ Resource Aggregation/ Deleting a Resource Aggregator
Updated on 2026-07-24 GMT+08:00
If a resource aggregator is no longer used, you can delete it.
  1. Log in to the Config console.
  2. In the navigation pane on the left, choose Resource Aggregation > Aggregators.
  3. In the resource aggregator list, locate the aggregator to be deleted and click Delete in the Operation column.
    Alternatively, in the upper right corner of the resource aggregator details page, click Delete.
  4. In the displayed dialog box, click OK.
    Figure 1 Delete Aggregator
Helpful Links
Viewing Aggregated Rules
