Modifying an Aggregator
You can modify the name and source accounts for an account aggregator at any time. However, you can only modify the name rather than source accounts for an organization aggregator.
The following procedure describes how to modify an account aggregator.
To modify configurations of an organization aggregator, you need the following permissions:
- organizations:organizations:get
- organizations:accounts:list
- organizations:delegatedAdministrators:list
- organizations:trustedServices:enable
- organizations:trustedServices:list
- Click
in the upper left corner of the page. Under Management & Governance, select Config.
- In the navigation pane on the left, choose Resource Aggregation > Aggregators.
- Locate the aggregator to be edited and click Edit in the Operation column.
Alternatively, in the upper right corner of the resource aggregator details page, click Edit to go to the Edit Aggregator page.
Figure 1 Modifying an aggregator - On the Edit Aggregator page, edit the name and source accounts.
- Click OK.
