Monitored Config Events
Event monitoring provides data collection, query, and alarm reporting for events. You can create alarm rules for both system events and custom events. When there are specified events, you will receive alarm notifications.
Namespace
SYS.RMS
Config Events That Can Be Monitored
Event Name |
Event ID |
Event Severity |
Description |
Handling Suggestion |
Impact |
Noncompliance notification |
configurationNoncomplianceNotification |
Major |
The evaluation result is non-compliant. |
Modify non-compliant resource configurations. |
None |
Compliance notification |
configurationComplianceNotification |
Info |
The evaluation result is compliant. |
None |
None |
