Help Center/ Config/ User Guide/ Advanced Queries/ Creating a Custom Query
Updated on 2026-07-24 GMT+08:00
You can use the query statements preset by Config or customize query statements based on resource configuration attributes to query specific cloud resource configurations.
This section includes the following content:
  1. Log in to the Config console.
  2. In the navigation pane on the left, choose Advanced Queries.
  3. Choose the Custom Queries tab and click Create Query in the upper right corner.
    Figure 1 Creating a query
  4. In the Query Editor, enter the query statements.
    On the left of the page, the Schema information is displayed. Schema information shows detailed resource attributes that are specified by the properties parameter in the statement. For details about the configuration example of the query statement, see Configuration Examples of Advanced Queries.
  5. Click Save Query and enter the query name and description.
    A query name can contain only digits, letters, underscores (_), and hyphens (-). It cannot exceed 64 characters.
  6. Click OK.
    Figure 2 Saving a query
    There is a limit to how many custom queries you can create. If you exceed this limit, you will receive a notification: "The maximum number of custom queries has been reached." Although the query cannot be saved, you can still run the query and export the results.
  7. Click Run and then view the query results. Up to 4,000 query results can be displayed and exported.
  8. Click Export above the list and select the format of the file to be exported (CSV or JSON).
  9. Click Execution Records to view details about when the query was executed and the query statements.
    You can perform the following operations:
    • Run: Run the query.
    • Copy: Copy the query statements.
    • Save: Save the query as a new one.
    After you close the browser window or log out, the execution records of advanced queries will be cleared.
    Figure 3 Execution records
Using a Predefined Query
You can modify the name, description, and statement of a default query or a custom query and save it as a new query. The following procedure uses a default query as an example.
  1. Choose Advanced Queries > Default Queries.
    All default queries are displayed in a list.
  2. Click Query in the Operation column for the target query.
    Alternatively, click the query name and then click Query in the lower right corner of the query overview page.
    Figure 4 Running a default query
  3. In the Query Editor, modify the query.
    For details, see Configuration Examples of Advanced Queries.
  4. Click Save As and enter the query name and description.
  5. In the dialog box that is displayed, click OK.
    After a new query is created, the new query becomes a custom query and will be displayed in the custom query list.
    On the Execution Records page, you can also save an existing query as a new query. For details, see Step 10.
    Figure 5 Saving as a new query
Advanced queries use ResourceQL, a subset of SQL SELECT syntax, to query resource configuration data. You do not need to call specific APIs for the query or use multiple APIs to download full data and manually analyze the data. ResourceQL can only query data from the resources table.
Table 1 Parameter descriptions in table resources
Type
id
String
Specifies the resource ID.
name
String
Specifies the resource name.
provider
String
Specifies the cloud service name.
type
String
Specifies the resource type.
region_id
String
Specifies the region ID.
project_id
String
Specifies the project ID.
ep_id
String
Specifies the enterprise project ID.
checksum
String
Specifies the resource checksum.
created
Date
Specifies the time when the resource was created.
updated
Date
Specifies the time when the resource was updated.
provisioning_state
String
Specifies the result of an operation on resources.
tag
Array(Map<String,String>)
Specifies the resource tag.
properties
Map<String,Object>
Specifies the resource attribute details.
Example quires are as follows:
  • Example 1: List ECSs in the Stopped state.
    SELECT name
    FROM resources
    WHERE provider = 'ecs'
     AND type = 'cloudservers'
     AND properties.status = 'SHUTOFF'
  • Example 2: List EVS disks with certain specifications.
    SELECT *
    FROM resources
    WHERE provider = 'evs'
     AND type = 'volumes'
     AND properties.size = 100
  • Example 3: List OBS buckets queried by fuzzy search.
    SELECT *
    FROM resources
    WHERE provider = 'obs'
     AND type = 'buckets'
     AND name LIKE '%figure%'
  • Example 4: List ECSs and the EVS disks attached to each ECS.
    SELECT ECS_EVS.id AS ecs_id, EVS.id AS evs_id
    FROM (
        SELECT id, evs_id
        FROM (
     SELECT id, transform(properties.ExtVolumesAttached, x -> x.id) AS evs_list
    	FROM resources
    	) ECS
    	   CROSS JOIN UNNEST(evs_list) AS t (evs_id)
    ) ECS_EVS, (
    	SELECT id
    	FROM resources
    	) EVS
    WHERE ECS_EVS.evs_id = EVS.id
  • Example 5: List ECSs and the EIPs bound to each ECS.
    SELECT ECS.id AS ECS_id, publicIpAddress AS ip_address
    FROM (
        SELECT id, transform(properties.addresses, x -> x.addr) AS ip_list
        FROM resources
    ) ECS, (
            SELECT name, properties.publicIpAddress
            FROM resources
            WHERE provider = 'vpc'
                AND type = 'publicips'
                AND properties.type = 'EIP'
                AND properties.status = 'ACTIVE'
        ) EIP
    WHERE CONTAINS (ECS.ip_list, EIP.name)
  • Example 6: List resources with a quantity greater than 100 in each region.
    WITH counts AS (
        SELECT region_id, provider, type, count(*) AS number
        FROM resources
        GROUP BY region_id, provider, type
    SELECT *
    FROM counts
    WHERE number > 100
    For details about query statements, see ResourceQL Syntax.
