Functions
ResourceQL supports the following functions.
Function |
Description |
abs(x) |
Returns the absolute value of x. |
ceil/ceiling(x) |
Returns x rounded up to the nearest integer. |
floor(x) |
Returns x rounded down to the nearest integer. |
pow/power(x, p) → double |
Returns x raised to the power of p. |
round(x) |
Returns x rounded to the nearest integer. |
round(x, d) |
Returns x rounded to d decimal places. |
sign(x) |
Returns the sign of x.
Function |
Description |
concat(str1, str2, ..., strn) → string |
Returns the concatenation of str1, str2, ..., strN. |
chr(n) → string |
Returns the Unicode code point n as a single character string. |
codepoint(str) → int |
Returns the Unicode code point of the only character of str. |
length(str) → int |
Returns the length of str in characters. |
lower/upper(str) → string |
Converts str to lowercase or uppercase. |
replace(str, sub) → string |
Removes all substrings from strings. |
replace(str, sub, replace) → string |
Replaces all instances of sub with replace in str. |
reverse(str) → string |
Returns str with the characters in reverse order. |
split(str, delimiter) → array |
Splits str on delimiter and returns an array. |
strpos(str, sub) → int |
Returns the starting position of the first instance of sub in str. Positions start with 1. If not found, 0 is returned. |
strpos(str, sub, n) -> int |
Returns the position of the N-th instance of sub in str. Positions start with 1. If not found, 0 is returned. |
strrpos(str, sub) → int |
Returns the starting position of the last instance of sub in str. Positions start with 1. If not found, 0 is returned. |
strrpos(str, sub, n) -> int |
Returns the position of the N-th instance of sub in str starting from the end of the string. Positions start with 1. If not found, 0 is returned. |
substr(str, start) → string |
Returns the rest of str from the starting position start. |
substr(str, start, length) → string |
Returns a substring with a length from the start index. |
trim/lstrim/rstrim(str) |
Removes leading and trailing whitespace from a string. |
Function |
Description |
all_match(array(T), function(T, boolean)) → boolean |
Returns whether all elements of an array match the given predicate. |
any_match(array(T), function(T, boolean)) → boolean |
Returns whether any elements of an array match the given predicate. |
array_average(a) → double |
Returns the average value of array a. |
array_distinct(a) → array |
Removes duplicate values from array a. |
array_frequency(a) → map |
Returns a map: keys are the unique elements in array, values are how many times the key appears. |
array_has_duplicates(a) → boolean |
Returns a boolean: whether a has any elements that occur more than once. |
array_intersect(a, b) → array |
Returns an array of the elements in the intersection of a and b, without duplicates. |
array_join(x, delimiter) → string |
Concatenates the elements of the given array using the delimiter. |
array_join(x, delimiter[, null_replacement]) → string |
Concatenates the elements of the given array using the delimiter and an optional string to replace nulls. |
array_max/array_min(a) |
Returns the maximum or minimum value of input array a. |
array_position(a, element) → int |
Returns the position of the first occurrence of the element in array a (or 0 if not found). |
array_position(a, element, instance) → int |
Returns the position of the first occurrence of the element in array a. If no matching element instance is found, 0 is returned. If instance > 0, returns the position of the instance-th occurrence of the element in array a. If instance < 0, return the position of the instance-to-last occurrence of the element in array a. |
array_remove(a, element) → array |
Removes all elements that equal element from array a. |
array_sort(a) → array |
Sorts and returns array a. |
array_sort(array(T), function(<T, T>, int)) → array |
Sorts and returns the array based on the given comparator function. The comparator will take two nullable arguments representing two nullable elements of the array. It returns -1, 0, or 1 as the first nullable element is less than, equal to, or greater than the second nullable element. |
array_sum(a) |
Returns the sum of all non-null elements of a. |
array_union(a, b) → array |
Returns an array of the elements in the union of a and b, without duplicates. |
array_except(x, y) → array |
Returns an array of elements in x but not in y. |
cardinality(a) → int |
Returns the cardinality (size) of array a. |
concat(a1, a2, ...) → array |
Concatenates the arrays a1, a2, .... This function provides the same functionality as the SQL-standard concatenation operator (||). |
contains(a, element) → boolean |
Returns true if the array a contains the element. |
element_at(a, index) |
Returns element of a at given index. If index < 0, element_at accesses elements from the last to the first. |
filter(array(T), function(T, boolean)) → array(T) |
Constructs an array from those elements of array for which function returns true. |
none_match(array(T), function(T, boolean)) → boolean |
Returns whether no elements of an array match the given predicate. |
reverse(a) → array |
Returns an array which has the reversed order of array a. |
sequence(start, stop, step) |
Generates a sequence of timestamps from start to stop, incrementing by step. It is similar to the range() function in Python, which returns a sequence of numbers, starting from 0 by default, and increments by 1 (by default), and stops before a specified number. |
shuffle(a) → array |
Generates a random permutation of given array a. |
slice(a, start, length) → array |
Subsets array a starting from index start (or starting from the end if start is negative) with a length of length. |
transform(array(T), function(T, S)) → array(S) |
Returns an array that is the result of applying function to each element of array. |
Function |
Description |
arbitrary(x) |
Returns an arbitrary non-null value of x, if one exists. |
array_agg(x) → array |
Returns an array created from the input x elements. |
avg(x)→ double |
Returns the average (arithmetic mean) of all input values. |
bool_and/bool_or(x) → boolean |
bool_and returns TRUE if every input value is TRUE, otherwise FALSE. bool_or returns TRUE if any input value is TRUE, otherwise FALSE. |
coalesce(value1, value2, ...) |
Returns the first non-null value in an argument list. Short-circuit evaluation will be used. |
count(*)/count(x) → int |
count(*) returns the number of input rows. count(x) returns the number of non-null input values. |
greatest(value1, value2, ..., valueN) |
Returns the largest of the provided values. |
histogram(x) → map |
Returns a map containing the count of the number of times each input value occurs. |
least(value1, value2, ..., valueN) |
Returns the smallest of the provided values. |
max/min(x, n=1) |
Returns n largest or smallest values of all input values of x. |
max_by/min_by(x, y, n=1) |
Returns n values of x associated with the n largest of all input values of y in descending order of y, or return n values of x associated with the n smallest of all input values of y in ascending order of y. |
geometric_mean(x) → double |
Returns the geometric mean of all input values. |
set_agg(x) → array |
Returns an array created from the distinct input x elements. |
set_union(x) → array |
Returns an array of all the distinct values contained in each array of the input. |
sum(x) |
Returns the sum of all input values. |
multimap_agg(key, value) |
Returns multiple mappings created from input key-value pairs. |
Returns the mapping created from the input key-value pair. |
Function |
Description |
now() → date |
Returns the current time. |
date_diff(unit, timestamp1, timestamp2) → int |
Returns timestamp2-timestamp1 expressed in terms of unit. The option of unit can be millisecond, second, minute, hour, day, week, month, quarter, or year. |
date_parse(string, format) → timestamp |
Parses a string into a timestamp using format. |
