Relationships with Supported Resources
Service |
Resource |
Relationship |
Related Service |
Related Resource |
Elastic Cloud Server |
Cloud servers |
isContainedIn |
Virtual Private Cloud |
VPCs |
Host Security Service |
Host agents |
MapReduce Service |
Clusters |
Contains |
Cloud Backup and Recovery |
Vaults |
isAttachedTo |
EIPs |
Vaults |
Elastic Volume Service |
Disks |
isAssociatedWith |
Security groups |
Image Management Service |
Images |
Bare Metal Server |
Cloud servers |
isContainedIn |
VPCs |
isAttachedTo |
Disks |
isAssociatedWith |
Security groups |
Images |
Hyper Elastic Cloud Server |
HECSs |
isContainedIn |
VPCs |
Contains |
EIPs |
isAttachedTo |
Disks |
isAssociatedWith |
Security groups |
Images |
Auto Scaling |
AS groups |
isContainedIn |
VPCs |
isAssociatedWith |
Security groups |
Distributed Cache Service |
Memcached instances |
isContainedIn |
VPCs |
isAssociatedWith |
Security groups |
Nodes |
isContainedIn |
Redis instances |
Redis instances |
isContainedIn |
VPCs |
Contains |
Nodes |
isAssociatedWith |
Security groups |
Elastic Load Balance |
Load balancers |
Contains |
Listeners |
isAttachedTo |
EIPs |
Backend server groups |
Active/standby backend server groups |
Listeners |
Is contained in |
Load balancers |
contains |
Forwarding policies |
isAttachedTo |
Contains |
Backend servers |
Is attached to |
Load balancers |
Listeners |
Contains |
Backend servers |
isAttachedTo |
Load balancers |
Listeners |
isContainedIn |
Listeners |
Backend servers |
isContainedIn |
VPCs |
Contains |
Cloud servers |
Bare Metal Server |
Cloud servers |
HECSs |
AS |
AS group |
DCS |
Memcached instance |
DCS |
Redis instance |
MRS |
Cluster |
VPC |
Flow logs |
EIPs |
Security groups |
isAssociatedWith |
Cloud servers |
Bare Metal Server |
Cloud servers |
HECS |
HECS |
AS |
AS group |
DCS |
MRS |
mrs |
DCS |
Redis instance |
isContainedIn |
Ports |
Flow logs |
isContainedIn |
Subnets |
Ports |
VPCs |
Ports |
Contains |
Flow logs |
Security groups |
Subnets |
Contains |
Flow logs |
Bandwidth |
contains |
VPC |
publicips |
Elastic IP |
isContainedIn |
VPC |
Bandwidth |
VPC |
isAttachedTo |
ECS |
Cloud server |
ELB |
Load balancer |
MRS |
MRS |
NAT Gateway |
Public NAT gateway |
EVS |
Volume |
Contains |
Vaults |
isAttachedTo |
ECS |
Cloud server |
BMS |
Cloud server |
Vaults |
HECS |
HECS |
IMS |
Image |
isAssociatedWith |
ECS |
Cloud server |
BMS |
Cloud server |
HECS |
HECS |
NAT Gateway |
isAttachedTo |
VPC |
Elastic IP |
GeminiDB |
Instances |
Contains |
GeminiDB |
Nodes |
Node |
isContainedIn |
GeminiDB |
Instances |
GaussDB |
Instance |
contains |
GaussDB |
Node |
Node |
isContainedIn |
GaussDB |
Instance |
MRS |
MRS |
isContainedIn |
VPC |
VPC |
isAttachedTo |
VPC |
Elastic IP |
isAssociatedWith |
VPC |
Security group |
contains |
ECS |
Cloud server |
CCE |
Cluster |
contains |
CCE |
Node |
Node |
isContainedIn |
CCE |
Cluster |
Enterprise Router |
Connection |
isContainedIn |
Enterprise Router |
Instance |
Instance |
contains |
Enterprise Router |
Connection |
Identity and Access Management |
Agencies |
isAssociatedWith |
Policies |
Roles |
User groups |
Contains |
Users |
isAssociatedWith |
Policies |
Roles |
Policies |
isAssociatedWith |
Agencies |
User groups |
Users |
Roles |
isAssociatedWith |
Agencies |
User groups |
Users |
Users |
isAssociatedWith |
Policies |
Roles |
isContainedIn |
User groups |
RDS |
Instance |
contains |
RDS |
Node |
Node |
isContainedIn |
RDS |
Instance |
Config |
Conformance package |
Contains |
Config |
Rule |
Rule |
Is contained in |
Config |
Vaults |
isAttachedTo |
ECS |
Cloud servers |
Disks |
Scalable File Service Turbo (SFS Turbo) |
SFS Turbo |
Policies |
isAttachedTo |
Vaults |
Vaults |
isAttachedTo |
Policies |
isContainedIn |
Cloud servers |
Disks |
SFS Turbo |
Document Database Service |
Instances |
Contains |
Nodes |
Node |
isContainedIn |
Instances |
Host agent |
Contains |
ECS |
Cloud servers |
Web Application Firewall |
Instances |
isContainedIn |
Policies |
Policies |
Contains |
Instances |
SFS Turbo |
Contains |
Vaults |
SFS Turbo |
isAttachedTo |
Vaults |
