Workspace Attached to a Backup Vault
Rule Details
Parameter |
Description |
Rule Name |
workspace-protected-by-cbr |
Identifier |
Workspace Attached to a Backup Vault |
Description |
If Workspace does not have a backup vault attached, the check result is non-compliant. |
Tag |
cbr, workspace |
Trigger Type |
Configuration change |
Filter Type |
workspace.desktops |
Rule Parameters |
None |
Application Scenarios
Workspace uses the desktop backup function of Cloud Backup and Recovery (CBR), ensuring user data integrity and service security.
Solution
Create a backup for your Workspace in a timely manner. For details, see Backing Up Desktop Data. Set a proper backup policy for automatic resource backup. For details, see Policy Overview.
Rule Logic
- If your Workspace is associated with an available backup vault, the check result is compliant.
- If your Workspace is not associated with an available backup vault, the check result is non-compliant.
