Workspace Backup Time Window
Rule Details
Parameter |
Description |
Rule Name |
workspace-last-backup-created |
Identifier |
Workspace Backup Time Window |
Description |
If Workspace does not have a backup created within the specified period, the check result is non-compliant. |
Tag |
cbr, workspace |
Trigger Type |
Periodic |
Filter Type |
workspace.desktops |
Rule Parameters |
lastBackupAgeValue: required backup time interval (in hours) for Workspace. |
Application Scenarios
Workspace uses the desktop backup function of Cloud Backup and Recovery (CBR), ensuring user data integrity and service security.
If the backup interval is too long, data loss risks increase. If data is damaged or lost between two backups, all changes and new data generated during this period will be lost. This may have a serious impact on services.
Solution
Create a backup for your Workspace in a timely manner. For details, see Backing Up Desktop Data.
Rule Logic
- If Workspace resources are backed up within the specified period, the check result is compliant.
- If Workspace resources are not backed up in the specified period, the check result is non-compliant.
