Backup Locked for CBR Vaults
Rule Details
Parameter |
Description |
Rule Name |
cbr-vault-locked-enabled |
Identifier |
Backup Locked for CBR Vaults |
Description |
If backup locking is not enabled for CBR vaults, the check result is non-compliant. |
Tag |
cbr |
Trigger Type |
Configuration change |
Filter Type |
cbr.vault |
Rule Parameters |
None |
Application Scenarios
You can enable backup locking for vaults to prevent backups from being deleted by mistake or maliciously.
Once enabled, all backups in the vault enter the write once, read many (WORM) state. No one can delete the backups in their retention periods.
Solution
Rule Logic
- If backup locking is enabled for CBR vaults, the check result is compliant.
- If backup locking is not enabled for CBR vaults, the check result is non-compliant.
