SSL-Encrypted Transmission for GeminiDB Instances
Rule Details
Parameter |
Description |
Rule Name |
geminiDB-instance-ssl-enable |
Identifier |
SSL-Encrypted Transmission for GeminiDB Instances |
Description |
If SSL is disabled for GeminiDB instances, the check result is non-compliant. |
Tag |
gemini db |
Trigger Type |
Configuration change |
Filter Type |
nosql.instances |
Rule Parameters |
None |
Application Scenarios
Without the use of Secure Sockets Layer (SSL), data transmitted between a GeminiDB instance and server is vulnerable to eavesdropping, tampering, and man-in-the-middle attacks. To improve data transmission security, enable SSL to encrypt communication.
Solution
Refer to the following steps to enable SSL encryption:
Rule Logic
- If SSL is disabled for GeminiDB instances, the check result is non-compliant.
- If SSL is enabled for GeminiDB instances, the check result is compliant.
