TaurusDB Database Engine Version
Rule Details
Parameter |
Description |
Rule Name |
taurusDB-instance-engine-version-check |
Identifier |
TaurusDB Database Engine Version |
Description |
If the TaurusDB database engine is earlier than the specified version, the check result is non-compliant. |
Tag |
taurusdb |
Trigger Type |
Configuration change |
Filter Type |
gaussdbformysql.instance |
Rule Parameters |
specifiedVersion: required TaurusDB database engine version. For details, see TaurusDB Version Release Policy. |
Application Scenarios
To ensure you have access to new features and avoid any known vulnerabilities or issues, it is recommended that you regularly upgrade your Taurus instance to a secure, stable, reliable MySQL version. Using an EOS version, you cannot obtain technical support and TaurusDB SLA assurance. Upgrade your TaurusDB instances in a timely manner.
Solution
Upgrade your TaurusDB instances on the management console. For more information, see Upgrading the Minor Version of a DB Instance.
Rule Logic
- If a TaurusDB instance uses a version earlier than the specified one, this instance is non-compliant.
- If a TaurusDB instance uses the specified version or higher, this instance is compliant.
