DCS for Redis Instance Port Check
Rule Details
Parameter |
Description |
Rule Name |
dcs-redis-port-check |
Identifier |
DCS for Redis Instance Port Check |
Description |
If a DCS for Redis instance is using a disabled port, the check result is non-compliant. |
Tag |
dcs |
Trigger Type |
Configuration change |
Filter Type |
dcs.redis |
Rule Parameters |
blockedPorts: ports disabled for DCS for Redis instances |
Application Scenarios
The default listening port of the Redis server is 6379, which is vulnerable to scanning attacks. You are advised to use another port.
Rule Logic
- If a DCS for Redis instance is using a disabled port, the check result is non-compliant.
- If a DCS for Redis instance is not using any disabled port, the check result is compliant.
