Updated on 2025-08-25 GMT+08:00
ECS Status Check
Rule Details
Table 1 Rule details
Rule Name
ecs-instance-status-no-stopped
Identifier
ECS Status Check
If an ECS is not in the stopped state, the check result is non-compliant.
Tag
ecs
Trigger Type
Configuration change
Filter Type
ecs.cloudservers
Rule Parameters
None
Application Scenarios
Stopped ECSs need to be detected and handled to prevent service interruption.
If an ECS is no longer needed, delete it to save costs. If such ECS has sensitive information, the data may be restored even if the ECS is shut down. Clearing the data before deleting the ECS can reduce security risks.
Solution
Check whether your ECSs are still required. If not, delete the ECSs. For details, see ECS Deletion and Unsubscription.
If the ECSs are still required, start and maintain them.
Rule Logic
  • If an ECS instance is not stopped, the ECS instance is compliant.
  • If an ECS instance is stopped, the ECS instance is non-compliant.
