ECS Memory Size
Rule Details
Parameter |
Description |
Rule Name |
ecs-instance-memory-check |
Identifier |
ECS Memory Size |
Description |
If an ECS has less memory than required, the check result is non-compliant. |
Tag |
ecs |
Trigger Type |
Configuration change |
Filter Type |
ecs.cloudservers |
Rule Parameters |
memorySize: minimum memory allowed, in GB |
Application Scenarios
You need to evaluate the service development requirements to ensure that the memory of an ECS is sufficient for service growth and prevent service interruption caused by insufficient specifications.
Solution
Scale up vCPUs and memory of your ECSs to meet service requirements. Certain ECSs support changing ECS types. For details, see Modifying Specifications of Individual ECSs.
Rule Logic
- If an ECS has less memory than required, the check result is non-compliant.
- If an ECS has memory greater than or equal to the required, the check result is compliant.
