Updated on 2025-08-25 GMT+08:00
Number of ECS vCPUs
Rule Details
Table 1 Rule details
Rule Name
ecs-instance-cpu-check
Identifier
Number of ECS vCPUs
If an ECS has fewer vCPUs than required, the check result is non-compliant.
Tag
ecs
Trigger Type
Configuration change
Filter Type
ecs.cloudservers
Rule Parameters
cpuCount: Minimum CPU cores
Application Scenarios
You need to evaluate the service development requirements to ensure that the number of vCPUs of an ECS is sufficient for service growth and prevent service interruption caused by insufficient specifications.
Solution
Scale up vCPUs and memory of your ECSs to meet service requirements. Certain ECSs support changing ECS types. For details, see Modifying Specifications of Individual ECSs.
Rule Logic
  • If an ECS has fewer vCPUs than required, the check result is non-compliant.
  • If an ECS has vCPUs greater than or equal to the required, the check result is compliant.
