Help Center/ Config/ User Guide/ Resource Compliance/ Built-In Policies/ API Gateway/ EIP Bound to a Dedicated API Gateway
Updated on 2025-08-25 GMT+08:00
Rule Details
Table 1 Rule details
Rule Name
apig-instances-no-public-ip-check
Identifier
If a dedicated API gateway instance has an EIP bound, this instance is non-compliant.
Tag
apig
Trigger Type
Configuration change
Filter Type
apig.instances
Rule Parameters
None
Application Scenarios
Binding an EIP to an API gateway instance allows direct access, which means that the backend service is exposed to threats from the public network.
Rule Logic
  • If a dedicated API gateway instance has an EIP bound, this instance is non-compliant.
  • If no EIP is bound to a dedicated API gateway instance, this instance is compliant.
