Dedicated API Gateway Bound to a Specified VPC
Rule Details
| Parameter | Description |
| Rule Name | apig-instances-in-vpc |
| Identifier | Dedicated API Gateway Bound to a Specified VPC |
| Description | If a dedicated API gateway instance is not bound to a specified VPC, this instance is non-compliant. |
| Tag | apig |
| Trigger Type | Configuration change |
| Filter Type | apig.instances |
| Rule Parameters | authorizedVpcIds: VPC IDs used by dedicated API gateway instances |
Application Scenarios
VPC allows you to create custom virtual networks in your logically isolated AZ. These networks are dedicated zones that are logically isolated for your ECS instances. You can define security groups, virtual private networks (VPNs), IP address segments, and bandwidth for a VPC. This facilitates internal network configuration and management and allows you to change your network in a secure and convenient manner. You can also customize the ECS access rules within a security group or between security groups to improve ECS security.
For more information about VPC, see VPC Service Overview.
Solution
Create a dedicated gateway in a specified VPC.
Rule Logic
- If a dedicated API gateway instance is not in any of the specified VPCs, this instance is non-compliant.
- If a dedicated API gateway instance is in any of the specified VPCs, this instance is compliant.
