Updated on 2025-08-25 GMT+08:00
RDS Instances Have Audit Log Enabled
Rule Details
Table 1 Rule details
Rule Name
rds-instance-enable-auditLog
Identifier
If an RDS instance does not have the audit log enabled or has audit logs kept for less than the specified number of days, this instance is non-compliant.
Tag
rds
Trigger Type
Configuration change
Filter Type
rds.instances
Rule Parameters
keepDays: number of days for storing audit logs
Application Scenarios
The database audit function records all user operations on the database in real time. This function logs, analyzes, and reports user activities in the database. Based on the audit logs, you can prepare compliance reports and track incidents, improving data asset security. For details, see Enabling Database Audit for Post-Event Backtracking.
Solution
Configure an audit log policy for your RDS instances as required. For details, see Setting SQL Audit and Enabling SQL Audit.
Rule Logic
  • If SQL audit is enabled for an RDS instance and the audit logs are retained for at least the required period, the instance is compliant.
  • If SQL audit is enabled for an RDS instance but the audit logs are retained for less than the required period, the instance is non-compliant.
  • If SQL audit is not enabled for an RDS instance, the instance is non-compliant.
