Private Images Have Encryption Enabled
Rule Details
Parameter |
Description |
Rule Name |
ims-images-enable-encryption |
Identifier |
Description |
If a private image does not have encryption enabled, this image is non-compliant. |
Tag |
ims |
Trigger Type |
Configuration change |
Filter Type |
ims.images |
Rule Parameters |
None |
Application Scenarios
Image encryption supports encrypting private images. When you create an ECS using an encrypted image, the system disk of the ECS is automatically encrypted. For details, see Encrypting Images.
Solution
Create an encrypted image from an external image file or an encrypted ECS.
Rule Logic
- If a private image does not have encryption enabled, this image is non-compliant.
- If a private image has encryption enabled, this image is compliant.
