VPC Check
Rule Details
Parameter |
Description |
Rule Name |
gaussdb-mysql-instance-in-vpc |
Identifier |
Description |
If a TaurusDB instance is not in any of the specified VPCs, this instance is noncompliant. |
Tag |
taurusdb |
Trigger Type |
Configuration change |
Filter Type |
gaussdbformysql.instance |
Configure Rule Parameters |
VpcIdList: VPC IDs. The value must be an array. |
Applicable Scenario
A VPC is a private network on the cloud. You can create VPCs to logically isolate your TaurusDB instances. For more details, see What Is Virtual Private Cloud?
Solution
You cannot change the VPC of a TaurusDB instance. Exercise caution when selecting a VPC. For details, see description of VPC in Buying a Pay-per-Use DB Instance.
Rule Logic
- If a TaurusDB instance is not in any of the specified VPCs, this instance is noncompliant.
- If a TaurusDB instance is in one of the specified VPCs, this instance is compliant.
