TaurusDB Instance EIP Check
Rule Details
Parameter |
Description |
Rule Name |
gaussdb-mysql-instance-no-public-ip-check |
Identifier |
TaurusDB Instance EIP Check |
Description |
If a TaurusDB instance has an EIP associated, this instance is non-compliant. |
Tag |
taurusdb |
Trigger Type |
Configuration change |
Filter Type |
gaussdbformysql.instance |
Rule Parameters |
None |
Application Scenarios
TaurusDB instances can be connected to over a private network, over a public network, or using Data Admin Service (DAS) or JDBC. For details, see Connection Methods.
You are advised to connect to a TaurusDB instance over a private network. Databases with EIPs can be accessed via the public network, which may increase the risk of attacks such as malicious scanning or attacks through exposed ports. In terms of performance, connecting to a database over the public network may increase the latency. The intranet usually has higher bandwidth and lower latency. For details, see Security Best Practices.
Solution
Unbind EIPs from TaurusDB instances. For details, see Binding or Unbinding an EIP.
Rule Logic
- If a TaurusDB instance has an EIP bound, this instance is non-compliant.
- If a TaurusDB instance does not have an EIP bound, this instance is compliant.
