Cross-AZ Deployment Check
Rule Details
Parameter |
Description |
Rule Name |
gaussdb-mysql-instance-multiple-az-check |
Identifier |
Description |
If a TaurusDB instance is deployed in an AZ, this instance is non-compliant. |
Tag |
taurusdb |
Trigger Type |
Configuration change |
Filter Type |
gaussdbformysql.instance |
Rule Parameters |
None |
Application Scenarios
An AZ is a physical location that uses independent power supply and networks. AZs in the same region can communicate with each other over an intranet.
If your workloads require cross-AZ DR or are insensitive to cross-AZ latency, you are advised to deploy the primary node and read replicas in different AZs to achieve higher availability and reliability.
Solution
When buying a TaurusDB instance, select multiple AZs.
Rule Logic
- If a TaurusDB instance is deployed in a single AZ, this instance is non-compliant.
- If a TaurusDB instance is deployed across AZs, this instance is compliant.
