Data Transmission Encryption Is Enabled
Rule Details
Parameter |
Description |
Rule Name |
gaussdb-mysql-instance-ssl-enable |
Identifier |
Description |
If a TaurusDB instance does not have SSL enabled, this instance is non-compliant. |
Tag |
taurusdb |
Trigger Type |
Configuration change |
Filter Type |
gaussdbformysql.instance |
Rule Parameters |
None |
Application Scenarios
Without the use of Secure Sockets Layer (SSL), data transmitted between a TaurusDB instance and server is vulnerable to eavesdropping, tampering, and man-in-the-middle attacks. To improve data transmission security, enable SSL to encrypt communication. For details, see Security Best Practices.
Solution
Refer to Configuring SSL for a DB Instance to set SSL configurations.
Rule Logic
- If a TaurusDB instance does not have SSL enabled, this instance is non-compliant.
- If a TaurusDB instance has SSL enabled, this instance is compliant.
