CCE Clusters Are in Specified VPCs
Rule Details
Parameter |
Description |
Rule Name |
cce-cluster-in-vpc |
Identifier |
Description |
If a CCE cluster is not in any of the specified VPCs, this cluster is noncompliant. |
Tag |
cce |
Trigger Type |
Configuration change |
Filter Type |
cce.clusters |
Configure Rule Parameters |
VpcIdList: VPC IDs. The value must be an array. |
Applicable Scenario
A Virtual Private Cloud (VPC) is a private network on the cloud. VPCs allow you to logically isolate you CCE clusters. You can design VPC networks based on your security requirements.
Solution
You can redeploy noncompliant CCE clusters to required VPCs. For details, see Modifying Cluster Configurations.
Rule Logic
- If a CCE cluster is not in any of the specified VPCs, this cluster is noncompliant.
- If a CCE cluster is in one of the specified VPCs, this cluster is noncompliant.
