DWS Clusters Are in Specified VPCs
Rule Details
Parameter |
Description |
Rule Name |
dws-clusters-in-vpc |
Identifier |
Description |
If a DWS cluster is not in any of the specified VPCs, this cluster is noncompliant. |
Tag |
dws |
Trigger Type |
Configuration change |
Filter Type |
dws.clusters |
Configure Rule Parameters |
VpcIdList: VPC IDs |
Applicable Scenario
A VPC is a private network on the cloud. You can create VPCs to logically isolate your DWS clusters. For more details, see What Is Virtual Private Cloud?
Solution
You can redeploy noncompliant DWS clusters to required VPCs.
Rule Logic
- If a DWS cluster is not in any of the specified VPCs, this cluster is noncompliant.
- If a DWS cluster is in one of the specified VPCs, this cluster is compliant.
